Old 04-30-2011, 09:04 AM   #1
dobbiedoo
Dobbiedoo
dobbiedoo's Avatar
Drives: 2009 5 door Hb Yaris
Rattle in rear
Anyone change their springs front and rear on a 2009 hatch and experience any noises (eg rattles, clicks) when I am driving? Could it be the springs are moving or maybe too short? I kept original struts. Ideas please.
dobbiedoo is offline   Reply With Quote
Old 05-01-2011, 11:23 AM   #2
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Retighten your nuts , check for loose debris in the spare tire well , check plastic panels to see if any have popped out , and check your passenger side seatbelts . They may be bumping against the plastic when you hit bumps .
Old 05-01-2011, 11:21 PM   #3
Hershey
The plastic panel attached to the rear hatch can rattle like crazy . Used sticky back felt to ease the noise . Had to have the other 1/2 drive on some poor streets while sitting in back seat listening and pinpointing the rattle(s) . Then applied the sticky felt to those areas . Did help some . The rattles seemed to get worse when the weather gets warmer . Likely due to expansion and the heat weakening the plastics ( less rigid ) . The brake light in the hatch window can rattle as well . May need felt for that too .
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Rear Rattle njyaris NY / NJ/ CT / PA 8 06-26-2007 09:25 AM
Rattle Causer in Rear? yaris-intuit DIY / Maintenance / Service 1 10-06-2006 06:56 PM
