#1 |
![]() Drives: Yaris 5 Door Liftback Join Date: Jun 2011
First Bar Disappeared @ 109 Miles...!!!
Is this a terrifically good sign? How soon does your first bar click off?
And I went with Blazing Blue... ![]() I'm having regrets. I should have @#$%ing gone with Meteorite! ![]() But the blue pulled me from the silver... ARGH. My feelings on Blazing Blue: ![]() ![]() ![]() ![]() ![]() :rolle yes:![]()
that's really good. my first bar usually goes at 50-60 miles. lol. i have a SLIGHTLY heavy foot.
![]() ![]() theres a pic of my meteorite just to spite you muahaha
#3 |
my first bar goes around 75 miles though I stop when the gas pump clicks once. not sure if that matters or not.
#4 |
The fuel sender stops registering after 11 gallons, so if the filler pipe was fully loaded, 109 is normal, as that can be 109 miles on over 3 gallons of gas. Here's an analysis I did a while back on the fuel sender response:
http://www.yarisworld.com/forums/sho...ght=fuel+level
#5 | |
![]() Drives: 2008 Toyota Yaris Sedan Join Date: Dec 2010
#6 |
![]() ![]() Drives: I'm back !! 2012 Toyota Yaris Join Date: Nov 2008
75 miles for me
best mpg so far, 46.1 !! Still shooting for 50 !
#7 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Look at the big picture: if you're odo shows about 400 miles at your next fill-up, then your'e fine.
Mine reads about 420 on it's final gallon.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#8 |
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
#9 |
The second bar disappeared @ 154 miles...
CANNOT WAIT TO SEE WHAT MY FIRST TANK BRINGS. Then I can see when the first bar disappears on my second tank. |
#10 |
420! hahaha..
#11 |
toyota
Drives: 2007 Yaris RS Blazed Join Date: Oct 2006
90 kms winter 110 summer , Eco driving mode 126 kms best hwy trip 140 kms
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
#12 |
I burned my fist tank (didn't count it) since it was filled at the dealership. my next two yielded me 41.5MPG each.
my dad has a 2006 corolla and he regularly tops 40mpg though he does a lot of highway driving. toyotas do great with mileage. I can't say for the trucks or the bigger cars but the smaller cars usually do really well. |
#13 |
![]() ![]() ![]() Drives: S Flint Mica Join Date: May 2006
As long as you drive conservatively, keep tires inflated to proper level, and are the only passenger in car, the Yaris should give you 35+ easily. I have a 07, Sedan, auto. Not much pick up speed but love the MPG.
#14 |
Fourth bar disappeared at 247 miles. What about you guys?
#15 |
![]() Drives: 2009 Yaris Hatchback Join Date: Mar 2011
My first bar always takes forever to drop, coming in at around 100 each time. But then there's a huge dive until about halfway or so that goes by really quickly. I commute about 40 miles per day taking no special steps besides not driving like a maniac ( I have inflated tires to 42 psi all around) and I have averaged 38 mpg on my last six tanks. There is a lot of mileage to be had on this car but as for the fuel gauge accuracy it's only really good for knowing when to fill up.
#16 |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Without running the tank down to fumes you should be able to safely reach 400 miles per tank..
#17 |
Joey
#18 |
![]() ![]() Drives: 2010 yaris sedan 4 speed auto Join Date: Apr 2012
PLEASE READ THIS....YARIS inTO PRIUS SECRETS...ROAD WISDOM..
thr first bar is about 2.4 gallons. most blogs complain about the gauge is not " EVEN" when using fuel. about38-40 mpg sounds about right. My 2010 auto 4 speed gets that but heres how you might get more 1. make sure air and oil filters are clean if not take to gas station and blow out air with air hose if still gray or brown...replace. 2. dino oil is fine check with trusted mechanic about swich to synthetic may only get 2-3 more per gallon .Weigh that with cost to see if thats good increse . or stick with Dino oil changes...do them like the manual says. 3. I dont over inflate my tires ever. mine are 195-15 size and the sidewall says 52 max. psi. Im at 37-38 psi ride is comfy. you can inflate to reduce road friction but tires will wear faster so keep them within the specs.. ...guess which is more expensive tires later, or gas right now.... ( answer...tires and rubber cost) 4. use what the epa calls "TOP TIER" gasoline. FINALY... DONT BE A DRAG LOOK AT YOU TUBE for eathier hypermiling tips or prius drive techniques ( which is why prius goes so far on gas... the dashboard is training the driver to "hypermile" and gives a video game to play for about 24K. The Yaris 1.5L engine is the same type as the prius c and the drag weight and other specs are pretty close to your yaris...the main diffrence beside low resistance tires and a little trimer body ... IS YOU AND HOW YOU CAN MAKE YOUR YARIS INTO A PRIUS, PRESTO... WITH KNOWLAGE...NOT TECHNO TRICKS. BE PROUD OF YOUR YARIS....ITS THE SECRET LOVE CHILD BETWEEN A CAMRY AND A PRIUS. ITS STRONG like dad AND SIPS GAS LIKE MOM....ENJOY Last edited by jay cobbs <posthistory.php?p=649284>; Today at 09:03 AM. Reason: real yaris secrects, yaris like prius, more mpg than before <report.php?p=649284> <report.php?p=649284> |
| Broke 50 MPG | STC | Fuel Economy Forum | 71 | 12-13-2010 01:04 PM |
| Tokico Blues + TRD Springs &Sway Bar after 5k miles | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 12-17-2009 11:11 PM |
| How many MPB (miles per bar)? | otterhere | Fuel Economy Forum | 56 | 07-15-2009 04:55 PM |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
