Old 10-19-2011, 02:31 PM   #1
Dj_SloKid
Dj_SloKid's Avatar
Drives: Yaris Sedan
Send a message via AIM to Dj_SloKid Send a message via Yahoo to Dj_SloKid
WILL IT RUB ???
??? will it Rub ???? 18x7.5 et 40 tire 205/40/18 yaris sedan dropped on df210 stock shocks, please help and if u have pics please post
Dj_SloKid is offline   Reply With Quote
Old 10-19-2011, 03:34 PM   #2
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
I had 18x7.5 42et with a 205 35 18 tire lowered on DF's and on stock shocks/struts and they rubbed on full lock turns and on my commute when there was a major dips or bumps mainly going downhill, overall they rubbed less then expected and the rubbing was upfront on the plastic fender liner.
Old 10-19-2011, 04:25 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
camber is your friend.
Old 10-30-2011, 05:28 PM   #4
Dj_SloKid
Dj_SloKid's Avatar
Drives: Yaris Sedan
anyone running this set up ????
Old 11-21-2011, 04:36 PM   #5
Dj_SloKid
Dj_SloKid's Avatar
Drives: Yaris Sedan
NO RUB!!!
Old 11-21-2011, 05:18 PM   #6
Put 2 people in the back, take it over some railroad tracks, then report back. Otherwise, looks good just sitting there.
Old 11-28-2011, 07:34 PM   #7
MUSKOKA800
MUSKOKA800's Avatar
Mine rub up front. Never out back, even loaded to the max.
Less rub now with the OEM -1.5 degree camber set-up. But the will still touch while high speed cornering and hitting dips. Seldom even now while running straight over swales or dips.
Winter boots on now so never a touch, but no dry traction either.
Need new shoes. Will this rub? psykobowler Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-01-2010 11:33 PM
Help! Tein S-tech with 195/55/15 will it rub?? evo165 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 08-21-2009 09:59 PM
Aftermarket exhaust systems that do not rub on the road! fuji Performance Modifications 10 04-28-2009 06:22 AM
Does +43mm rub? Split Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 02-28-2009 07:39 PM
want 2 lower with tein but have tyre rub HELP! MR. CANTON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-24-2007 04:16 PM
