Old 03-20-2012, 08:11 PM   #1
bugg_master
Drives: yaris sedan type s
headlights out! :(
hey u guys i need help...i was driving home in the country side with my high beam and my lights just went out(low beam + high beam out). just checked the fuses today but theyre fine so i think i might get some new fuses to switch them just in case but does anyone have any ideas or suggestions about what the cause of the problem is?
bugg_master is offline   Reply With Quote
Old 03-20-2012, 09:03 PM   #2
There are two separate fuses for the two sides H-LP RH and H-LP LH.
Does the headlight icon light up on the cluster?
Old 03-21-2012, 04:23 PM   #3
bugg_master
hey ct the headlight icon actually does not come on :( i hope its not something bad
Old 03-21-2012, 05:25 PM   #4
Check the ECU-B fuse in the under hood fuse panel.
Old 03-21-2012, 05:46 PM   #5
bugg_master
CT the high beam icon does not come on but the low beam icon works,I double checked it again, does this change anything?
Old 03-21-2012, 06:51 PM   #6
The high beam indicator is separate from the headlights on indicator. The headlights on one is driven by the control side of the circuit and the high beam indicator is driven by power flowing through the bulbs, so if both bulbs were bad, that would be one possible explanation.
Old 03-21-2012, 07:32 PM   #7
Besides verifying that both bulbs aren't completely bad, check the H-LP/AMT Relay in the little box on the passenger side, under the hood. Have someone else turn the headlight switch on and off, while you listen closely for the relay to click as they do.
Sedan HID Projector Retrofit Headlights !yaris! Cosmetic Modifications (Exterior/Interior) 10 10-26-2017 02:31 AM
2010 yaris Projector headlights yaris2010RS Items for Sale by private party 9 01-09-2012 05:31 PM
Headlights Dpudg General Yaris / Vitz Discussion 5 09-04-2011 03:18 PM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
