Old 04-20-2012, 02:24 PM   #1
B-rad
Drives: yaris
filter on top of air box
wondering if removing the factory built in air filter on the top of air box will help my milage or possibly hurt the engine?
B-rad is offline   Reply With Quote
Old 04-20-2012, 02:30 PM   #2
Slight improvement to f/e.
However, that upper filter is a CARB requirement. Being in Cali, I'm not sure you'd pass inspection with it removed. From what I understand, inspection is a pretty anal issue down there.
Old 04-22-2012, 10:28 AM   #3
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Do you mean the filter that is behind the passenger side bottom glove box?
Big Dave
Indianapolis, IN
Old 04-22-2012, 10:51 AM   #4
No. In the air intake there are two filters. A white fiber filter that sits on the lower portion of the air box, and a permanently affixed black charcoal filter attached to the upper part. He is talking about the charcoal filter.
Old 04-22-2012, 12:31 PM   #5
daf62757
daf62757's Avatar
So if you remove the carbon filter you get better mileage?
Big Dave
Indianapolis, IN
Old 04-22-2012, 01:30 PM   #6
B-rad
Drives: yaris
yes the black carbon filter, its looks like its quite air restrictive.
iam wondering how the smog police would know i removed it and if the engine would still run properly?
Old 04-22-2012, 03:53 PM   #7
auxmike
auxmike's Avatar
I'm guessing it's just to hold in fuel vapors after the engine shuts down. Mabye without it there would be a gas smell....
Old 04-26-2012, 01:47 PM   #8
Uber_Otter
Uber_Otter's Avatar
Drives: Black XA not yaris but close
I pulled mine out of my Xa, big improvement in flow. Very noticable at the top of the rpm range. I broke it pulling it, you can dremel it out carefully and be able to put it back. It blocks noise as well, so now there is more of a growl out of the front. No gas fumes noticed. Not sure on MPG. I know it did not go down.
Uber_Otter is offline   Reply With Quote
Old 04-26-2012, 02:13 PM   #9
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
pulled mine out also.. mine was easily pulled off.. no damage.
-Derrick-
Old 04-26-2012, 04:47 PM   #10
daf62757
daf62757's Avatar
The Obama EPA will crucify you for that. You have admitted publicly to defiling a clean air system. You will be punished for your sin!
Big Dave
Indianapolis, IN
air filter part number? sigh willygoodness DIY / Maintenance / Service 4 04-17-2011 10:32 AM
Simota Carbon Charger Cold Air Intake lilredrocket Performance Modifications 18 04-13-2009 03:16 AM
damaging or no--cabin air filter roxy84 DIY / Maintenance / Service 3 06-29-2007 01:17 PM
