Old 05-25-2012, 02:44 AM   #1
clarenceie
Drives: Yaris Sedan
URGENT: Help Drum/Parking Brake problem
Hey guys, I recently bought a used 2007 Yaris Sedan
I noticed that the rear brake squeal after I used the brake a lot and a minor squeak when i sit in the car. I confirmed that the rear drums were completely locked even though the hand brake was down.
I tried to adjust it, but it just becomes locked again. I noticed that the parking lever in the brake assembly is very sticky, as in it won't retract properly.
I'm a total noob at drum brakes. Can you guys share how to fix this?
Thank you!
clarenceie is offline   Reply With Quote
Old 05-25-2012, 02:54 AM   #2
clarenceie
Drives: Yaris Sedan
Also pix of a correct drum brake of a Yaris would be great. The service manual doesn't depict it well. Specifically, I need a view of the parking lever untensioned.
Old 05-25-2012, 06:39 AM   #3
Here are pics of the top and bottom with as much visible as possible around the hub:
Old 05-25-2012, 01:17 PM   #4
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
< threadjack >
Scott, do you just have pics like this laying around, or do you take them on demand when things like this pop up? ;0)
< /threadjack >
Old 05-25-2012, 02:45 PM   #5
Originally Posted by suckerface View Post
< threadjack >
< /threadjack >
I took them when I had the drums off for painting. I figured that eventually either myself or someone else would need them for reference.
Old 05-25-2012, 06:29 PM   #6
swidd
Drives: Yaris HB
I hereby add a reminder to my phone: "Nobel Candidate that man".
Old 05-26-2012, 11:52 AM   #7
clarenceie
Drives: Yaris Sedan
Hey CTScott, thank you very much!
I checked over, and everything looks like in the same place.
I've seen other toyotas and other cars really with a parking brake return spring. It seems that the Yaris doesn't have one...
Is this a common problem in the Yaris? I live in SoCal. No rust on the car.
Old 05-27-2012, 01:15 AM   #8
CoryM
Drives: 2009 5-door, 5-speed
I assume by parking lever you mean #1 in the picture? Typically you will see two problems. Most common is a stiff or seized cable, and less common is a stiff or seized pivot on #1.
With the drum off, pull the parking brake handle enough to move the lever (#1). Then release the parking brake handle (lower it) and inspect the cable (#2). If the cable is straight and taut, the cable is the problem (does not extend). If the cable is curved and slack, the lever is stuck.
If a cable you generally just replace them. They can be lubed, but usually with limited success. If the lever is stiff you will have to take the brakes apart and clean/lube.
Hope this helps.
Old 05-27-2012, 01:55 AM   #9
clarenceie
Drives: Yaris Sedan
You're awesome Cory! Yes, I did notice that when I was operating the brake. I noticed that the cable was bent a little when hand brake was released. I sprayed some cleaning brake clean onto the whole assembly and that seems to take care of it, for now at least...
I noticed that on this drum assembly, it doesn't have a dedicated lever return spring as with other cars.
Again, definitely appreciate it Cory.
Old 06-01-2012, 01:34 PM   #10
Lafiro
Drives: 06 Yaris Sedan
This is awesome because mine do not adjust much, at least one side anyway, causing the car to not stop correctly after about a month or two.
What should I use to clean everything next time I take them apart?
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
rear brake light problem kaazio In Car Entertainment + Electronics (audio / video / alarm) 6 02-11-2011 05:27 PM
Brake pedal vibrates-not rotor problem rradhay DIY / Maintenance / Service 9 11-12-2010 09:10 AM
Brake problem 1saneguy General Yaris / Vitz Discussion 15 11-24-2008 03:56 AM
