Old 06-20-2012, 12:40 PM   #1
Foofutter
Foofutter's Avatar
Drives: 2009 Yaris Hatch
2009 Yaris Replacement Key
Good afternoon everyone,
I recently purchased a used 2009 Yaris, which I absolutely adore. The dealership (which is still trying to swindle me out of $500 through fraudulent means, long story there) only gave me one key for the car. It is black and says Strattec on the keybase. I'm dreading a yes, but does this model and year require a special key to be made and programmed? And if so, what's the cheapest way to go about this? I refuse to go back to my dealership as I'm about to open a lawsuit on them, and I imagine most other dealerships will charge me $300+ for a key.
Thanks everyone!
Foofutter is offline   Reply With Quote
Old 06-20-2012, 01:12 PM   #2
For 2009 all US Yaris have transponder keys. Part number: 89785-60160
You can pick them up for under $10 from ebay, get them cut at your local HW store, and program them yourself, using the procedure on page EI-12 of the "Engine Immobilizer" section of the service manual (which you can download on the Micro Image Forum):
http://www.microimageonline.com/foru...32-YARIS-FILES
Old 06-20-2012, 02:18 PM   #3
Foofutter
Foofutter's Avatar
CTScott,
Thank you so much for the information! Very much appreciated.
Old 09-22-2012, 03:19 AM   #4
jezzachezza
Drives: Yaris'10
Greetings,
3 months back, I thought I lost my spare grey key. Had a locksmith come do a replacement and reset the entire immobiliser so the lost key, though can enter the car, would not be able to start the engine.
I recently found the spare key and I wanted to know if there's a way I can load and replace the immobiliser code back onto the lost key so I can get it to be functional again?
It's a 2010 yaris. Hope some expert here can help.
Thanks.
jezzachezza is offline   Reply With Quote
Old 09-22-2012, 07:49 AM   #5
Originally Posted by jezzachezza View Post
Greetings,
Thanks.
Take a look at that document. I believe that the only way to register keys with the immobilizer cleared is using the Toyota service tool.
Old 09-22-2012, 10:05 AM   #6
jezzachezza
Drives: Yaris'10
Sorry if I misunderstood. Are you saying, I'll have to pop by a specialist?
Edit: No worries, I tried as you indicated. Works fine now. The old key seems to crank and start up the engine! But unlike the black key where inserted, the red lights goes off immediately. The old key once inserted, gives a 1-1.5sec solid red light before going off. I'm hoping this would not be an issue. Nevertheless, helped solve my issue enabling spare key to start up engine.
Old 09-22-2012, 10:53 AM   #7
I think that is OK. It may just be an indicator of master versus slave keys.
Old 08-17-2015, 03:47 AM   #8
NuMystic
Drives: 2008 Toyota Yaris 4D Sedan
Site is no longer available. Where can I download this now?
NuMystic is offline   Reply With Quote
Old 08-19-2015, 01:10 PM   #9
rcvmini
Drives: 2009 Yaris HB
I bought a tool off ebay that let me recode a used key I bought off ebay. I took off the transponder chip. Moved it into a flipout key body AND had a new blade for the key cut (for $2 at a local locksmith) Cost for the rekey tool $16. Used key ($30) with transponder and remote door controls. *note you only need the tool for the transponder. I was able to recode the door locks using the brake-open-close-door-dance
Total cost was like $50 (thats also with the aftermarket folding key body)
http://www.ebay.ca/itm/Toyota-Lexus-...item4ab4ec4b77
I also bought a $4 bluetooth OBD II code reader to check my own engine codes.
the dealership wanted $240 plus 1 hour for reprograming plus $25 to cut the key... so like almost $400 with tax
rcvmini is offline   Reply With Quote
Old 08-23-2015, 09:27 PM   #10
CoryM
Drives: 2009 5-door, 5-speed
Some reason I am unable to get my 09 into key-relearn mode. I've been following the Mitchell instructions (which often are crap), which is the same as the 07 (old key in, remove and insert 4 more times, door 6 times, remove old key and insert new). Old key is black so I assume it's the master, but maybe not. I was only given one key, and do not know history.
Rcvmini, I am in Langley so if I can't make this work, maybe we can work something out?
Cheers.
Cory
Old 08-24-2015, 01:24 AM   #11
rcvmini
Cheers.
Cory
Hey Cory,
The rekey tool i got from ebay will allow you to set a new master I'm in Coquitlam by the iKea so if you cant figure it out I might be able to help.
Just to be clear the ReKey tool only reprograms the transponder chip. The fob controls for your auto locks etc need be done with the key-in key out door dance and have NOTHING to do with the transponder chip that lets you start the car.
In simple terms the key in key out and open and close door dance will let you reprogram auto lock and unlock on a key fob but will NOT let you reprogram a used or new key that isn't alredy set you your car.
Thats where the rekey tool from ebay comes in. With that you don't need to play the dealer a bajillion-dollers to recode the transponder.
Old 08-24-2015, 07:20 PM   #12
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
I think I would cry if I lost one of my over-sized, overpriced keys.
Kalispel is offline   Reply With Quote
Old 08-25-2015, 10:23 PM   #13
CoryM
I'd thought the door dance was to relearn the key chip (not the fob). I don't have remote locks so only need the key.
It's odd because they say:
"The key has 2 codes: the key code (immobiliser code) and
the wireless code (recognition code)."
and "New key code registration (Without using intelligent
tester)" and then the door dance.
Either way if you have a setup that works, may as well give it a shot. I'll PM you in a few weeks when I have more time and we will give it a shot.
Thanks for the help.
Cheers.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Yaris 2006 Key Fob smpillai11 DIY / Maintenance / Service 9 11-04-2011 06:24 PM
