Old 09-09-2012, 09:24 PM   #1
nookandcrannycar
Idle issue...
CT,
Idle all of a sudden rough after battery install. I drove 63 miles after install. Then car parked for a few hours. Then drove about 20 miles, idle still not better. I did some grocery shopping and then looked under the hood while still in the parking lot. The technician (after replacing the battery) put the air filter in but didn't close the housing at all. What damage could I have done by driving 80+miles like this? After snapping the housing back together and reclamping, the idle only got slightly better.
Old 09-09-2012, 10:57 PM   #2
Lippitt
Drives: honda accord
Yaris idle faults
I think all the info you need is right here on this forum
http://www.yarisworld.com/forums/showthread.php?t=31656
Hope that helps…
Lippitt is offline   Reply With Quote
Old 09-10-2012, 05:49 AM   #3
nookandcrannycar
Originally Posted by Lippitt View Post
Yaris idle faults
Hope that helps…
Thanks. And thanks as well to CT for answering the other post I did on this.
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
Idle Fluctuation due to aftermarket intake? Galavoxx Performance Modifications 38 12-31-2011 08:31 AM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 05:31 PM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
