Old 10-28-2012, 03:58 AM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
drilled the wrong hole, what now?
i was installing a switch today and i didnt realize there's a metal piece behind it and I couldn't put the switch it. I am now left with a hole like this. Any idea what i should do to cover it up? how much is it if I buy the whole piece?
thanks
caineroad is offline   Reply With Quote
Old 10-28-2012, 05:24 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Old 10-28-2012, 09:16 AM   #3
Ouch. That lower dash assembly is a good junkyard find part. The other option would be to cover that little section with some adhesive vinyl.
Old 10-28-2012, 09:36 AM   #4
dindy
metallic green vitos
Drives: 2002 toyota vitz. 1.0 auto
Send a message via MSN to dindy
nah...if i was you i would buy a piece of plastic and fix it on it....
dindy is offline   Reply With Quote
Old 10-28-2012, 09:40 AM   #5
GTBaker
GTBaker's Avatar
Drives: 2012 Yaris LE
GTBaker is offline   Reply With Quote
Old 10-28-2012, 10:34 AM   #6
NEexpat
Drives: 2009, auto, 4dr LB
Finish and clean up the cut, find a switch that will fit the opening, gut it flat, (dremel it shallow so it fits)
install.
Serves no purpose other than camouflage.
NEexpat is offline   Reply With Quote
Old 10-28-2012, 10:38 AM   #7
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Best solution eva
Originally Posted by sw07gt
Old 10-28-2012, 11:35 AM   #8
kimona
kimona's Avatar
Drives: 2014 White VITZ
install.
^THIS^ or find a blank that will fit.
Old 10-28-2012, 12:14 PM   #9
daf62757
Nothing beats a Toyota!
daf62757's Avatar
The plastic jack holder under your driver's seat should be the same color. Just cut a small rectangle a little larger than your unfortunate plastic surgery malpractice error and glue it over. It shouldn't be that noticeable.
Big Dave
Indianapolis, IN
Old 10-28-2012, 12:19 PM   #10
Kar98
Drives: 2011 Scion tC
What's this hole in my air intake? Yury General Yaris / Vitz Discussion 22 01-23-2012 07:00 PM
Big BAD-ASS Brakes...Drilled xbgod Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 09-15-2010 07:54 PM
Drill hole in Driver's glovebox? Revsson In Car Entertainment + Electronics (audio / video / alarm) 6 07-05-2010 05:26 PM
Screwdriver popped a hole behour General Yaris / Vitz Discussion 5 01-30-2010 08:05 PM
Spoiler installation gone wrong jinxor Cosmetic Modifications (Exterior/Interior) 7 03-24-2009 12:13 AM
