Old 03-05-2013, 02:51 PM   #1
tb69396
Drives: 2007 Yaris HB
Replacement key fob w/out FCC ID - Help me
I purchased two keys with fob integrated for my 2007 Yaris. I can't get them to program at all. I tried about 5 times. Here is where I got them from and they have no FCC ID on remote anywhere so I can't tell if it is just different or not.
http://www.ebay.com/itm/120721106318...witem=&vxp=mtr
I am wondering if anyone else has had this issue or dealt with this Ebay seller. I have an email in to them but am waiting for a response.
tb69396 is offline   Reply With Quote
Old 03-05-2013, 03:54 PM   #2
There is a another thread where I went back and forth with someone on this same issue. From what I found the 2007 uses a different key than all of the years after.
Old 03-05-2013, 04:07 PM   #3
tb69396
oh really? I will search for it again then unless you know what the difference is?
Old 03-05-2013, 04:11 PM   #4
The difference is that the 07's have a different FCC ID, so the 08+ fobs will not work. So, in your case, you want to make sure that fob that you purchase matches the FCC ID of your key, as opposed to trusting the seller in the year compatibility.
Old 03-05-2013, 04:15 PM   #5
tb69396
That being the problem. No FCC ID. Don't know how to figure that out.
Old 03-05-2013, 04:19 PM   #6
Here's the post I was thinking of with the FCC ID info:
http://www.yarisworld.com/forums/sho...68&postcount=6
Old 03-05-2013, 04:47 PM   #7
tb69396
Thanks for the info. They said there are two different frequencies for the 2007 and they are going to send me the other one. We'll see if it works.
Old 03-05-2013, 09:05 PM   #8
clarenceie
Drives: Yaris Sedan
I have an 07 Sedan S, but the original key it came with was the MOZB41TG, which is the 08-11... Just thought I put it out there. CTScott's programming instruction worked like a charm.
clarenceie is offline   Reply With Quote
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
Busted Key Fob...Replacement? Z00KA DIY / Maintenance / Service 4 09-28-2012 12:04 PM
Yaris 2006 Key Fob smpillai11 DIY / Maintenance / Service 9 11-04-2011 06:24 PM
Key fob locks but won't unlock Pingouin DIY / Maintenance / Service 2 09-15-2010 03:53 PM
Replacement key / keyless entry mcduck DIY / Maintenance / Service 4 08-30-2010 06:52 PM
