Old 05-24-2013, 02:57 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Wheel Bearing Upgrade?
Is there only the OEM offering or is anyone aware of an upgraded bearing kit? Just curious since I need to replace my front driver's bearing soon.
Old 05-24-2013, 03:17 PM   #2
OEM is fine for all applications, no upgrade is needed.
Old 05-24-2013, 03:40 PM   #3
RedRide
RedRide's Avatar
Also, keep in mine that any "upgrade" would consist of a larger bearing which would mean that all related parts like spindle, brake disk, etc would need to be replaced also to accommodate it, assuming an upgrade was even available.
Old 05-24-2013, 03:46 PM   #4
fnkngrv
fnkngrv's Avatar
Ok, thanks guys. Appreciate it! Wasn't sure if it would make a difference when excessive speed is involved.
Old 05-24-2013, 04:08 PM   #5
fnkngrv
fnkngrv's Avatar
I did find out as well that there are two different P/Ns for future reference:
90363-40079 with abs
90363-40082 without abs
toyotapartszone.com has them for roughly 43 bucks each.
Old 05-24-2013, 04:37 PM   #6
enviri
enviri's Avatar
Drives: 2010 Yaris
go 5 lug :)
Old 05-24-2013, 05:46 PM   #7
RedRide
RedRide's Avatar
I believe that's because ABS has a different spindle and brake disk
Yaris 2007 ABS & Brake light issue after wheel bearing change DevilzMafia DIY / Maintenance / Service 4 01-17-2013 09:24 PM
Rear wheel bearing LeetViet DIY / Maintenance / Service 1 08-29-2012 07:41 PM
Installing Rear Wheel Bearing Hub brad4ds Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 07-22-2011 06:34 PM
Front Wheel Bearing Failure craigq DIY / Maintenance / Service 4 08-17-2007 07:26 AM
