Old 07-16-2013, 12:13 AM   #1
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
When to shift
Hello Everone,
I'm bringing up a topic already discussed in this post, http://www.yarisworld.com/forums/showthread.php?t=5979.
It says to never let the RPMs rise over 2k or 2.2 for merging. As some of you know I'm new to yaris and I'm new to the manual world. So my shifting is really crappy,and not smooth. I usually shift at 2.5k because I kind of let the RPMs drop trying to find the catch point between shifts. Should I try the 2k shifting?
vaironl is offline   Reply With Quote
Old 07-16-2013, 12:19 AM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
If you want to save fuel, sure. If you want to get where you're going, shift based on the current driving conditions, terrain and when you feel like it.
Old 07-16-2013, 09:03 AM   #3
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I used to shift at 2k for the fuel savings but it tends to put you around 1200rpms at the next gear. that is alright as long as you don't have to accelerate quickly.
The yaris also reacts well to shifting around 5500rpms and it is a lot more fun...
Old 07-16-2013, 11:25 AM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
i shift at 4000 all day everyday...
-Derrick-
Old 07-16-2013, 11:52 AM   #5
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
when the needle starts bouncing off the redline
Fuel cutoff shifts FTW
Old 07-16-2013, 12:27 PM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
When I was in ECO driving mentality I would do the whole shifting around 2k-2200, but really I find the best spot for smooth shifting being at the following which you might want to try until you are more comfortable:
4k, 5k, 5800
shifting I have noticed between 2500-4k seems to be more blunt.
DISCLAIMER: I am not responsible for any information I have provided. I am just relying on my 6 year experience with the C50.
Old 07-16-2013, 02:21 PM   #7
harda toenail
Drives: Want a yaris
Just keep driving and do what feels right for you. You will get the feel for when to shift depending on power needs and the situation. Everyone drives a manual differently. There isn't really a set way you need to shift. Enjoy the drive!!!
harda toenail is offline   Reply With Quote
Old 07-16-2013, 03:45 PM   #8
BEEF
BEEF's Avatar
Back in the day, there used to be a little light (arrow pointing up) to tell you when to shift. I found out quickly that if you floor it, the light goes off...
Old 07-17-2013, 12:20 AM   #9
I don't think shifting at 2000 rpm gives the best mileage, and it usually bogs the motor if you're trying to accelerate. At least 3000 rpm will make the car a lot happier.
Old 07-17-2013, 12:41 AM   #10
I used to shift at 2k rpm when ever I was able to creep up in speed. But since getting heavier wheels, I'm now shifting between 2.5k and 3k.
Old 07-17-2013, 12:49 AM   #11
nookandcrannycar
My Yaris doesn't have a tach. I pretty much follow this ^^^^^.
Old 07-17-2013, 01:06 PM   #12
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've made some spreadsheets and charts to figure out speed vs rpm (before I had a tach). Here's a post that has the stock gears vs their redline shift speeds: http://www.yarisworld.com/forums/sho...53&postcount=9
Old 07-17-2013, 04:40 PM   #13
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
New manual transmission corvettes lock out gears 2 and 3 when in eco mode. This forces you to go from first to fourth.
Some GM engineer thinks it is best to do most of your acceleration in first and then maintain speed with the higher gears.
FYI...after the fourth gear shift has been done, you are allowed to downshift to second or third.
Old 07-17-2013, 06:37 PM   #14
^ That's the goofiest thing ever. Who would want to hypermile a Corvette?
Old 07-17-2013, 08:03 PM   #15
Flipper_1938
Somebody that builds corvettes. .....That doesn't want to get hit with gas guzzler taxes.... that doesn't want to take a big hit on their CAFE average....GM.
Old 07-17-2013, 08:58 PM   #16
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
100% true for me at least... tried doing the 2000rpm-for-"best"-economy and didn't get the world's best results... but at around 3000-3200rpm I'm good to go!
Fuelly lists my last 10 fill-up average at 39.7mpg, and that's with consistent 3k shifts!
Old 07-18-2013, 12:09 AM   #17
Yup, each car is different. When I drove BailOut's LB, he told me to drive 55 mph in it since that's where he got the best mpg. Then I applied it to my car for almost a year, and got fed up with the not so great mpg I was getting. So I started experimenting and found that going 60-75 mph (just keeping the throttle at 24%) produced the best mpg for my car. hahaha. Last tank for me was 39.4 mpg with mostly city driving and I kid you not, 95% of all stop lights I encountered turning red on me last second. Also, with having to rotate 43.5 lbs in each corner. HAHA
Old 07-18-2013, 12:09 AM   #18
nookandcrannycar
Thanks. Interesting info.
Back to school sale Short shifter, Shift Knob, EVERYTHING is on sale! TWM Performance TWM Performance 13 09-29-2009 10:55 AM
TWM Performance weighted shift knobs on sale! TWM Performance TWM Performance 5 06-30-2009 09:58 AM
New shift knobs available from TWM Performance! TWM Performance TWM Performance 3 06-25-2009 04:24 PM
October sale on TWM Performance shift knobs! TWM Performance TWM Performance 1 10-31-2008 05:01 PM
