Old 07-25-2013, 04:40 AM   #1
SePtRa
Drives: 2000 Land Cruiser & 2007 Yaris
Exclamation Rev Issue On Idle
Hi all...
After driving me mad I've come to you for some help....
So i have a 2007 1.0 Yaris Sol...
And for some time there is a issue... When i put the car in neutral and lower my speed the revs drop too low and then the car has to accelerate by himself to recover this happens 2 or 3 times in a row....
Today as i'm diving home the this happened but some I've felt new symptoms too.. when i am accelerating the car seems to pause for a second and the go...
I've been to Toyota but nothing has been done...
Thanks in advance!!!!
SePtRa is offline   Reply With Quote
Old 07-25-2013, 08:39 AM   #2
Is the A/C on when this happens?
Old 07-25-2013, 12:47 PM   #3
SePtRa
No A/C Off... I Also forgot to say that doesn't happen every day.
I have a Mini VCI Cable with Techstream. I will try to check for error codes.
Old 07-25-2013, 02:07 PM   #4
Also, watch the data from the MAP sensor on your 1.0L with the techstream while it is occurring.
Old 07-26-2013, 04:38 AM   #5
SePtRa
So i went back to the car yesterday... No codes have been found...
I also watched the Map sensors as you said CTScott the values are:
~100 Kpa when its stopped.
As soon as i started the car i went down to around 30 kpa...
Unfortunately the issue did not occur when i was on the techstream...
Old 07-26-2013, 05:24 AM   #6
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Could the car be running too lean due to a vacuum leak. It will cause rough idle and see the RPM fluctuation, and hesitation during acceleration.
Check out my Build thread:
Old 07-29-2013, 11:42 AM   #7
SePtRa
New development...
Now when I start the car after a night on the garage it makes a Buzzing noise... Its loud enough to listen inside the car with everything closed..
Old 07-29-2013, 12:10 PM   #8
New development...
That may be the fuel pump. The service manual for your engine seems to point to most issues, like what you are experiencing, being caused by the fuel pump.
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
rough idle.... dindy Third Gen Yaris General Discussion 5 06-12-2013 12:48 PM
3rd gen 1zz tb swap mr_miles DIY / Maintenance / Service 26 05-01-2013 08:20 AM
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
Idle issue... nookandcrannycar DIY / Maintenance / Service 2 09-10-2012 05:49 AM
