Old 08-04-2013, 08:36 AM   #1
dindy
metallic green vitos
Drives: 2002 toyota vitz. 1.0 auto
Send a message via MSN to dindy
coil on plug testing with multimeter?
i found out that it might be a faulty coil on plug for cel sometime light on and rough idle. but on start on back the car, it goes off and on later on....so i checked for resistance between the pins of the each coils, and found that 3 of my coils resistance is from
pin 1-2 (346)
pin 1-4 (1420)
pin 2-4 (1563)
pin 2-3 (1100) for 3 coils.
But the other is totally different.
pin 1-2 (309)
pin 1-4 (1756)
pin 2-4 (1870)
pin 2-3 (1146) for 1 coil of them
think that is the trouble maker? cel never stands on all time! sometimes it goes on, but as i shut down the car and restart it stays off, but later, specialy in idle in traffic it goes on with rough idle and with no hesistation on driviong normal speed. any help guys?
dindy is offline   Reply With Quote
Old 08-04-2013, 09:01 AM   #2
The coil pack contains a bit of circuitry, so measuring the resistance of the input pins won't tell you all that much. Have you read the code to see that the DTC is always on the same cylinder?
Old 08-04-2013, 01:00 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
Moved thread to correct section.
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 03:32 AM
coil testing jstantherprsn DIY / Maintenance / Service 2 03-30-2011 05:53 PM
WTB: coil on plug connector Moses Willing to Buy by private party 1 12-15-2010 04:29 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
