Old 12-03-2013, 03:37 PM   #1
Yarisstance
TURBO MUTT
Drives: 2007 Toyota Yaris 4dr Hatch
Transmission issues!
So i own a 2007 Toyota yaris 4door hatchback. It is the automatic 1.5L. It has been a very good car to me especially in winter. But this morning i was doing alot of driving in the new snow running around town. All of the sudden when i start my car after it being parked for a couple hours i shift into reverse and the transmission started to rattle and make a shitty noise. The noise only happens in reverse and no other gears. I do let the car warm up and i do monitor my fluid levels often. I am praying that there is ice or snow jammed up in the car as i have been dragging on the snow around town. Anybody know whats going on i have a feeling I am losing reverse.
Yarisstance is offline   Reply With Quote
Old 12-03-2013, 03:42 PM   #2
Since it only makes the noise in reverse, it is likely the shift cable rattling against the exhaust heat shield.
Old 12-03-2013, 03:49 PM   #3
Yarisstance
TURBO MUTT
How could i check this to be sure? sorry xD and i love the snow plow yaris!
Old 12-03-2013, 04:05 PM   #4
To be sure you would have to jack it up and take a look underneath.
Old 12-03-2013, 04:22 PM   #5
Yarisstance
TURBO MUTT
Okay thanks ill have to take a look haha!
Old 12-03-2013, 04:37 PM   #6
There are several threads on here discussing this rattle. They are quite old since the issue has not been raised in quite some time. Not sure of the best search terms to find them.
Here's one of them http://www.yarisworld.com/forums/sho...mission+rattle
Old 12-03-2013, 06:37 PM   #7
Yarisstance
TURBO MUTT
So here i went and zip tied what i thought was the shift cable. It did not fix the rattle i hope i am wrong!
Old 12-03-2013, 06:44 PM   #8
That is the cable. As I mentioned in your cross post, the exhaust shield could also be to blame.
Old 12-03-2013, 06:45 PM   #9
Yarisstance
TURBO MUTT
When my car idles the rattle begins and it matches the idle. You definetly do not think its the transmission though?
Old 12-03-2013, 07:38 PM   #10
Check for free play in your various heat shields. Your car is old enough that the mounting points are probably corroded badly. Lost my first one last year.
Old 12-03-2013, 10:34 PM   #11
Hershey
Our '08 sedan has done this since day 1 . Seems worse with the frigid temps . Must have the shivers , shaking off the cold .
Old 12-03-2013, 10:35 PM   #12
No. If the tranny was making the noise you would have far worse issues with it.
Old 12-03-2013, 11:16 PM   #13
nookandcrannycar
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
My 2010 yaris is on its 4th transmission!! Help please Uzairlexus DIY / Maintenance / Service 12 07-16-2013 10:46 PM
need experts helo on robotic transmission clutch mariann DIY / Maintenance / Service 0 10-03-2012 12:51 PM
Transmission & Reverse Twistoffate0817 DIY / Maintenance / Service 4 08-28-2012 06:50 PM
Automatic Transmission issues?? Lawrence Berk DIY / Maintenance / Service 9 07-02-2009 01:12 PM
