#1 |
![]() Drives: 07 yaris sedan Join Date: Nov 2013
Rocker Switch
Looking for a rocker switch (SPST, lighted or non-lighted) that will fit in one of the openings in the console behind the shifter, to the right of the parking brake. 2007 Yaris Sedan.
Check out digikey.com. You will get tired of wading through all of the choices you will see there.
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 09:22 AM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| Replacement Map Light Switch? | Meteorite_Marty | Cosmetic Modifications (Exterior/Interior) | 8 | 11-12-2013 10:18 PM |
| replacement fog light switch? | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 4 | 07-17-2007 04:11 PM |
