Old 03-16-2014, 05:21 PM   #1
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
blitz supercharger problem
Hey guys, I recently bought a used blitz supercharger kit. I have it all wired up and ready to go, and I can't get the clutch on the compressor to engage. I even tried bypassing the switch and hooking a 12 volt connection directly to it and it doesn't engage.
Help? XD
Black_griffin6 is offline   Reply With Quote
Old 03-16-2014, 07:23 PM   #2
Black_griffin6
Can the clutch go bad? Do I need to replace it?
Old 03-16-2014, 10:40 PM   #3
Measure the resistance between the two clutch wires. If it reads as open, then the solenoid within the clutch is bad.
Old 03-17-2014, 05:24 PM   #4
Black_griffin6
Alright. So if it is bad, what are my options in terms of fixing it?
Old 03-17-2014, 05:56 PM   #5
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I've heard Blitz USA's customer support is pretty bad. Maybe look into just switching it for a fixed pulley?
Old 03-17-2014, 07:15 PM   #6
Black_griffin6
That might be an option. I've been looking for one just in case. Although I would like to stay around safe boost levels because I'm only on stock internals.
Do you know where I can get one?
Old 03-17-2014, 08:57 PM   #7
Check with Micro Image as well. Garm seems to have somewhat of a spare Blitz parts supply.
Old 03-18-2014, 04:13 PM   #8
Black_griffin6
Alright, I'll check with Garm too.
So if I get a fixed pulley can I just bolt it onto the supercharger?
Old 03-18-2014, 04:35 PM   #9
Yes - In place of the clutch pulley assembly.
At that point you will no longer use the Blitz fuel controller though. You will need to go with another form of fuel management.
You could also modify the existing clutched pulley to make it fixed.
Old 03-18-2014, 05:53 PM   #10
Black_griffin6
I have the Aem F/IC hooked up, but it's not currently on. I'm using the bypass wire.
When I tried to start the car after the installation of the supercharger, I had the FIC hooked up and it wouldn't start, not sure what the map is on there since it's a used unit.
Do you think the Aem piggyback would work?
How could I mod the current clutch pulley to be fixed?
Old 03-18-2014, 08:35 PM   #11
The F/IC would be fine for tuning it.
For converting the bad clutch to fixed, the simplest way to do so would be to weld the two sides together.
Old 03-18-2014, 08:56 PM   #12
Black_griffin6
Okay, excellent.
Would I need a waste gate or blow off valve?
Old 03-18-2014, 09:49 PM   #13
Okay, excellent.
No. The clutch does not disengage to allow the unit to blow off, so it seems to be internally limited, or perhaps limited by RPM.
I did see someone with an underdrive pulley mention producing more than the 6psi that mine tops out at.
Old 03-19-2014, 01:41 PM   #14
Black_griffin6
so it appears that the solenoid my clutch is bad. Do you have a diagram of what the clutch looks like so I may attempt to weld it?
It's currently still on car, so I'm trying to avoid taking the supercharger off the car again due to it being kind of a hassle to do so.
Old 03-19-2014, 02:08 PM   #15
The picture below shows the pulley. The outermost plate rotates freely if you try while the engine is off. You would need to weld it to the actual pulley (with the belt groove) to make it become fixed.
FS: BLITZ SUPERCHARGER SPROCKIT Items for Sale by private party 17 02-12-2014 04:39 PM
fs blitz supercharger staypuft Items for Sale by private party 3 10-12-2010 06:58 PM
anyone with Blitz supercharger? yrsdrgn Performance Modifications 52 08-24-2010 07:57 AM
So Whats Blitz Supercharger 0-60 run??? marcus Performance Modifications 19 10-02-2009 06:59 PM
fixed my blitz s/c problem for now laszlo Forced Induction Forum 3 04-19-2009 10:24 PM
