Old 05-14-2014, 06:25 AM   #1
SKurj
Drives: 09 Yaris 3dr HB, BRZ
Brake Upgrades
With thoughts to run the Yaris in lapping days, what are the suggested brake upgrades for the car? (without going to a big brake kit)
SKurj is offline   Reply With Quote
Old 05-14-2014, 10:27 AM   #2
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
You don't need anything more than better pads.
Old 05-14-2014, 11:17 AM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I can second that from what I have seen and experienced too. Going crossdrilled, etc on the rotors doesn't really gain you anything and unless mistaken actually will just cause your pads to wear out quicker even if you go with a higher end composition on the pads.
xnamerxx is someone you can easily trust on perspective for it too.
Old 05-14-2014, 11:22 AM   #4
marauder
marauder's Avatar
Drives: '08 Yaris
I'm on OEM brakes, the best upgrade to my brakes was my suspension and tires. The car will throw you through the windshield it stops so quick. I would imagine changing to a pad designed for track (hawk, etc...) would be beneficial in withstanding excessive heat.
marauder is offline   Reply With Quote
Old 05-14-2014, 02:11 PM   #5
SKurj
Thanks, any thoughts on braided ss brake lines?
Old 05-14-2014, 02:27 PM   #6
Jason@SportsCar
They provide a slightly better pedal feel, but wont do anything to help reduce brake fade or improve stopping power - the pads, ABS, and your tires are typically the limiting factors when it comes to stopping. They are a nice add on after you have upgraded your pads, just for piece of mind. Go with a set that have a coating over the SS, it helps prevent road grime and grit from penetrating the braiding and damaging the core.
Old 05-14-2014, 03:31 PM   #7
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Sports Pads and possibly high temp fluid.
When I ran my xB once on completely stock brakes and it did well. I had to replace the pads shortly afterwards tho!
My tercel track day car has been thru several evolutions of brake upgrades as I have gotten faster. Currently have Mazda protege rotors, corolla calipers with Porterfield race pads, super blue fluid, and brake ducting. About to take the plunge into Wilwood land soon...
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-14-2014, 03:45 PM   #8
marauder
marauder's Avatar
Drives: '08 Yaris
What is the 60-0 stopping distance with your current setup? How much distance are you looking to shave off that number?
Old 05-14-2014, 04:43 PM   #9
SKurj
Sorry for my newbness...
Anyone able to suggest a brand/model of brake pads and brake fluid I should look for (hopefully something fairly common I have a little over a week to get what I need)
Think the oem pads are pretty well worn so want to gettem swapped in time. The event is May 24.
How do the oem rotors hold up for events? Hear of some cars that can chew up a set of rotors with a single track day..
Old 05-14-2014, 05:10 PM   #10
xnamerxx
0-60 in slow
xnamerxx's Avatar
Seeing its a street car Hawk HPS should be fine.
Old 05-14-2014, 06:21 PM   #11
Jason@SportsCar
Hawk pads.
Ford or ATE fluid is very good for occasional track use.
I can run for more than a year on a set of rotors and pads. I have used OE rotors, Centric and whatever Pep-Boys has in stock, no noticeably difference in life.
Old 05-14-2014, 06:53 PM   #12
SKurj
Thanks guys! got all I need to know now I think...
1st ever track day, pretty excited! I've got thousands of virtual laps in... none of the real thing tho..
Hoping this one goes well and will lead to yet another expensive hobby
Old 05-14-2014, 07:35 PM   #13
Heading to Cayuga or Mosport?
Old 05-14-2014, 07:50 PM   #14
SKurj
DDT May 24 the spda atts event
Old 05-14-2014, 10:04 PM   #15
malibuguy
Obsessed with 1.5L
This. I was very happy with these when I was starting out.
Really good street performance and characteristics while still handling track heat. I had 2 weekends and 20k~ on them before I changed my set up and they still had 1/2 their life left.
-96 Tercel 4dr
Old 05-16-2014, 03:36 PM   #16
SKurj
Got the pads ordered, looked up a diy on pad replacement, looks like it will only take an hour to do both sides. Now to see if I can find a pressure bleeder anywhere local in time.
Old 10-18-2014, 03:43 PM   #17
mitchell12
mitchell12's Avatar
Drives: 2007 yaris HB
Um you shouldn't need to bleed your brakes for just the pads unless you are being proactive and flushing the system.
mitchell12 is offline   Reply With Quote
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Brake upgrades for my SCION tC cali yaris Off-topic / Other Cars / Everything else Discussions 8 07-11-2009 02:23 AM
Brake upgrades majorposer Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 06-06-2007 03:43 AM
Brake Upgrades for Yaris Hatch! ItalianYaris Performance Modifications 33 05-09-2007 02:29 AM
