Old 05-19-2014, 01:15 PM   #1
nortonfb
Drives: 2007
Wheel Questions
I was offered a set of Primax 772 in 16".
Which has a bolt pattern of 4 lug 4.25 inch 108mm High Positive Offset.
The offset I really don't understand.
What would I need to use these?
Is it worth the effort?
Thanks,
Steve
nortonfb is offline   Reply With Quote
Old 05-19-2014, 01:42 PM   #2
The 4x108 means you would need hub adapters to use them. This would add positive offset and the fact that the rims are already "high" positive offset means that they would stick out as is, let alone with a hub adapter in between.
Old 05-19-2014, 03:10 PM   #3
Yaristeve
Drives: 3-door hatch
Adding a spacer would reduce the postive offset.
Old 05-19-2014, 03:25 PM   #4
Some day I will get that correct off the top of my head. So, to correct my statement to the OP, the "high" offset wheels would potentially be tucked in too far (depending on what "high" equals). In that case the hub adapters could be chosen thickness wise to offset that extra tuck and bring the wheels out to the correct spacing for the car.
Old 05-19-2014, 05:31 PM   #5
Yaristeve
I understand; you sound like you're an old timer, like me.
The current, accepted sign convention (more negative moves mounting face inward) is illogical to me too. In the old days, a more positive offset made the wheel track more wide, ie.: +offset = +track.
Now it's more negative offset makes the track more wied. Huh?
Old 05-19-2014, 11:19 PM   #6
nortonfb
Drives: 2007
I think I have it now.
Think I'll just wait for some thing else.
Steve
Old 05-19-2014, 11:31 PM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
yea, there are tons of wheels from miatas and civics that fit our cars, no need to get ones that require adapters.
Colin Chapman disciple
Old 05-20-2014, 12:00 AM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Mazda2 is direct fit
Sent from my XT1032
Replacement Radio + Steering Wheel Control Questions dinop In Car Entertainment + Electronics (audio / video / alarm) 0 07-07-2013 02:31 PM
Some wheel and tire questions Liu997 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 08-14-2009 11:33 PM
Wheel offset questions.. Jerkratt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 11-04-2008 02:32 AM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
