Old 06-10-2014, 11:39 PM   #1
Henry_mak16
Henry Mak
Drives: 2009 Toyota Yaris 2dr-hatchbk
Driver-side door unresponsive to wireless key
Good evening yarisworld!
I gladly installed a tachometer in my car. However, I barely noticed (a week later) that my driver's side door isn't responding to my wireless key (other doors respond). In addition to that, my left side mirror isn't responding to the electronic adjuster.
I'm not sure if these two issues are immediate results of the day I installed my tachometer. I want to guess I maybe pulled a wire loose or something under there.
My question is:
How could I trace the problem? What are your suggestions?
Thanks!
Henry_mak16 is offline   Reply With Quote
Old 06-11-2014, 08:46 AM   #2
I would start by checking the connection at the kick panel (driver's side since this is the side that is not working) The door electrical connections are there.
ie, did you yank any wires out of there while plugging your tach to the ODBII connector?
Old 06-11-2014, 02:51 PM   #3
Henry_mak16
Henry Mak
I was a little rough, but all I did was cut the wire I needed and soldered. Theres no obvious loose electrical connections, any way I can tell specifically which wire?
Old 06-11-2014, 03:01 PM   #4
I don't remember what the 2nd gen kick panel looked like when i had it open before..
but this is what is looks like on a 1st gen.. Whatever plugs there goes into the door.
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 07:29 PM
Driver side Seat Belt gwasabi DIY / Maintenance / Service 13 05-09-2009 06:45 AM
Driver side foglight trim gwasabi Willing to Buy by private party 3 03-03-2009 03:11 AM
Replacing driver side mirror? supernes550 Cosmetic Modifications (Exterior/Interior) 4 01-26-2009 11:11 AM
The Driver Side River Nutzoids General Yaris / Vitz Discussion 7 12-14-2006 01:11 AM
