Old 07-27-2014, 03:49 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
removing the dash
If I want to replace my AC compressor I also need to vaccum out the whole system of debris that a broken compressor can leave thru out the pipes and other parts.I have
talked to a couple pros and they both say you cant just stick a new compressor on it and go. I would have to pull the whole dash and remove and clean or replace the blower unit
that actually blows cool air out the vents. It can have debris in it...
How can you remove the entire dash and is it a nightmare???Has anyone seen this
unit under there??? What does it look like??
yaris9876 is offline   Reply With Quote
Old 07-27-2014, 04:17 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Have you checked out the OEM repair manual yet? It has all of the steps for replacing/repairing everything.
Old 07-27-2014, 06:27 PM   #3
You don't need to take the dash apart to do it. You use an AC vacuum pump to draw a vacuum on the system. A high end AC vacuum pump will have an indicator as the number of microns that it has purge the system down to.
Make dash less slippery to set coffee cup alpha1 General Yaris / Vitz Discussion 11 11-19-2012 10:39 PM
removing lower dash mal1953 DIY / Maintenance / Service 2 08-14-2011 10:01 AM
Help removing dash JCHanlon DIY / Maintenance / Service 4 08-17-2010 03:30 PM
wanting to paint my dash flat black but have a question removing knobs YarisSedan DIY / Maintenance / Service 0 07-08-2009 01:55 PM
Removing A-pillar/partial dash H8SGAS DIY / Maintenance / Service 0 09-02-2006 09:03 PM
