Old 09-16-2014, 01:03 PM   #1
hairdresserscar
Drives: 07' Yaris sedan
subaru strut homebrew coilovers!
Today i installed gc8 subaru struts, with ebay coilover sleeves, and its a pretty stiff ride with plenty of lows. ill post pictures later with my car cleaned up a bit. note how close the perch is to the mount vs yaris
hairdresserscar is offline   Reply With Quote
Old 09-16-2014, 01:44 PM   #2
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
How did you come to pick subaru struts?
Old 09-16-2014, 05:55 PM   #3
hairdresserscar
i had a legacy and noticed the perch for the spring was lower and immediately thought moar lower. then i thought maybe a vehicle weighing twice as much might have more dampening so i threw them in!
Old 09-16-2014, 06:23 PM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Do the bolts on the new strut line up with the three holes in the strut tower on the Yaris?
Old 09-17-2014, 12:12 PM   #5
hairdresserscar
iirc
there are only two holes in the yaris but i swapped the top hats over
Old 09-17-2014, 12:48 PM   #6
CrankyOldMan
Aah, clever. How hard is it to find the crash/camber bolt spacing on struts?
Old 09-17-2014, 03:42 PM   #7
hairdresserscar
wellllll i used a plasma cutter...
Old 09-17-2014, 04:11 PM   #8
CrankyOldMan
Oh, well in that case, disregard.
Old 09-17-2014, 04:42 PM   #9
hairdresserscar
the results! excuse the dirt and cracked out bumper, as a rural paper route is NOT forgiving to a slammed yaris
Old 09-17-2014, 09:04 PM   #10
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Interesting...
I need to find some shorter struts for my tercel...if those fit the Yaris then they are way too big for the terkle spindle
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-23-2014, 07:57 PM   #11
Flipper_1938
What coilover kit did you use with the subi struts and yaris top hats?
Old 09-26-2014, 04:11 PM   #12
hairdresserscar
search coilover sleeve honda on ebay its the yellow ones 55 shipped
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
***2002 ECHO,Rear Apexi Coilovers to be modified to fit, Energy Sus bushings *** Hussain-Vtec Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-27-2012 06:55 PM
trade yaris for subaru wrx, maybe sti? Fenrizwolf Off-topic / Other Cars / Everything else Discussions 24 09-10-2010 09:48 PM
cusco coilovers installed badhabitz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 02-03-2007 04:43 PM
C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 01-10-2007 06:53 PM
