Old 04-23-2007, 05:49 PM   #1
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
Noise when braking
i hear a noise when braking firmly, like something is knocking 2-3 times in the front of the car...
before having it checked, did that happen to anyone else
hystria is offline   Reply With Quote
Old 04-24-2007, 04:59 PM   #2
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
I don't have this problem, however, I have another problem with the brake. When I'm stopped, and applied the hand brake, I have to pull the handle pretty high in order to get the car to steady, or else it will be making squaking sound when I step out of the car or moving inside the car. Is this because of the Drum brake? As this is the first car I have drum brake on. Thanks.
GabL is offline   Reply With Quote
Old 04-24-2007, 08:22 PM   #3
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
um have you had anything worked on for your car in the front? does it happen uphill downhill flat roads?
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 04-24-2007, 08:27 PM   #4
drifto
drifto's Avatar
yeah you need to adjust your e-brake
http://www.etimago.com/yaris/repairm...ng%20Brake.pdf
07 Yaris LB 5spd
Old 04-26-2007, 05:49 PM   #5
hystria
hystria's Avatar
springs changed... probably some bolt not tight enough...
Old 04-26-2007, 06:00 PM   #6
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
thats ur abs....
if it knocks during hard braking its your abs system... antilock braking system.. thats normal..comes in handy on winter....nothing to worry about.
Old 04-30-2007, 07:16 PM   #7
MeggiemobileSFLA
Drives: yaris sedan
If its more of a "click click" and you can hear inside the car, I had the same problem. Had to have the brake switch replaced which is up under your steering wheel area.
MeggiemobileSFLA is offline   Reply With Quote
Old 04-30-2007, 08:07 PM   #8
hystria
hystria's Avatar
it comes actually from the front brakes area - no abs
did check it, with no results as far
Old 04-30-2007, 11:04 PM   #9
drifto
drifto's Avatar
well if you had springs done. the strut bolt may be too loose or a strut mount bolt may not be torqued properly. i would check them out first. if so it will sound like the brakes are loose during braking or on bumpy roads.
07 Yaris LB 5spd
Old 05-02-2007, 09:28 AM   #10
nsmitchell
nsmitchell's Avatar
As a side note, only use Toyota OEM brake pads. Cheap pads on Toyotas and Hondas will squeal even if you use all the brake quiet goo possible.
Get YarAss in gear!
RIP - Casey Tatum
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
2007 LB Auto-Trans NOISE in Reverse Pavel Olavich General Yaris / Vitz Discussion 4 03-22-2007 07:42 PM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 11:03 AM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 10:45 PM
Noise in the A/C System cburac DIY / Maintenance / Service 1 05-16-2006 06:14 AM
