Old 04-07-2015, 01:00 PM   #1
Engine Coolant Temp sensor
Anyone know where this sensor is located? I'm assuming that there may be 2 one for the dash and another for the ECU.
It's for an '02 Echo but I'm assuming the position is the same for the 1NZ. I looked in the repair manual and cannot find a diagram showing it and I want to inspect is as I think it may have been the issue for the rough start in cold weather this past winter (needed to depress the pedal to keep car at idle for first minute in really cold weather).
Thanks
Engine light came on but seems to run fine naossoan DIY / Maintenance / Service 7 06-10-2013 04:51 PM
Changing engine coolant spookybathtub DIY / Maintenance / Service 2 03-24-2011 10:00 PM
Coolant Temp Sensor location? Yeti DIY / Maintenance / Service 7 05-06-2009 10:13 AM
Coolant level when engine cold CB900F2 DIY / Maintenance / Service 4 04-05-2009 11:12 AM
