Old 04-29-2015, 06:22 AM   #1
bronsin
bronsin's Avatar
How To Make Your Clutch Last Forever!
Im 59 this year and have never replaced any part of a clutch in any of my vehicles. The clutch in my 74 VW went 250,000 miles.
Heres how I did it!
1) No holding the clutch in at lights. No holding the car on hills with the clutch.
2) Never slip the clutch except when moving off in 1st. And as little as possible then.
3) Use no throttle when shifting except when moving off in 1st. And as little as possible then.
4) Clutch pedal must be either on the floor or up in the air with your foot off it.
If you can do this your clutch will reward you with long life!
Old 04-29-2015, 08:17 AM   #2
Heres how I did it!
And if you're just learning, tires are cheaper than a clutch replacement.
Old 04-29-2015, 09:44 AM   #3
WOT shifting...
Old 04-29-2015, 11:38 AM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
You can pick up a clutch for 300. Tires worth having will run you 80+ pop ;-)
Old 04-29-2015, 11:45 AM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
But swapping tires will take 15 minutes. Swapping a clutch, not so much. =P
Old 04-29-2015, 11:45 AM   #6
fnkngrv
fnkngrv's Avatar
lol...this is true even with this car!
Old 04-29-2015, 11:48 AM   #7
I give a little throttle to rev match when going from 1-2 and 2-3, this makes for a smoother shift and should decrease the wear on a clutch
Old 04-29-2015, 02:07 PM   #8
justjesus
justjesus's Avatar
Drives: 2008 Liftback
My coworker thought he was doing this as well. He couldn't explain HOW it's rev matching, when UPshifting.
Revs DROP when going up through the gears.
Old 04-29-2015, 04:21 PM   #9
nookandcrannycar
Heres how I did it!
I pretty much agree, and I've put somewhere between 800k-900k miles on manual transmission cars (about 650k on just 3 cars, with the least traveled of those clocking 151k). I've never tried to replace a clutch, and have never needed to replace one. I did have to have the clutch on my Suzuki Swift adjusted at about 80,000 (IIRC) miles, but a friend did it for me for free. The issue is even more peripheral now that I no longer live in a hilly area.
Old 04-29-2015, 05:14 PM   #10
CrankyOldMan
It depends on how fast you change gears, as well as how fast your crankshaft winds down. If you have a lightweight crank pulley and/or flywheel, you will likely have to blip the throttle when upshifting as well.
Old 04-29-2015, 05:15 PM   #11
Rev match is definitely not the right word (although I do that when shifting down all the time to save the clutch). I give a slight bit of gas when letting out the clutch from 1-2 and even less from 2-3 gear. It gets rid of the rough shift normally found in low gear shifts.
Feel free to chime in as to why giving no gas at all at low gear shifts causing a rough shift and giving gas smooths it out. I'm assuming it's the same reason why you need to give a bit of throttle going from stop to 1st. Due to the lag of a slow moving transmission and a faster moving engine. Giving it gas helps ease the connection between the two.
Old 04-29-2015, 08:44 PM   #12
colj00
DIYer
Drives: yaris 1.5 MT
i thought this was basic knowledge, yet i see a lot of peoples cars rocking back and forward on hills because they were holding it with the clutch, its infuriating to watch. :P
many times waiting for the revs to drop when changing from 1-2 can take what feels like a few weeks, so most of the time i say screw it, im slippin ya.
colj00 is offline   Reply With Quote
Old 04-29-2015, 09:58 PM   #13
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
Heres how I did it!
And I do everything as you have posted, yet they had to replace my clutch due to the throwout bearing. This is the first clutch I've ever had to replace and I've been driving manuals for a long time. I think I counted owning 14 previous cars with MT and this is the first.
DebbyM46227 is offline   Reply With Quote
Old 04-30-2015, 01:02 AM   #14
Secretblend
Drives: 2009 Yaris
Speaking of saving clutches? Does anyone here ever shift up to higher gear without using clutch?
Secretblend is offline   Reply With Quote
Old 04-30-2015, 03:42 AM   #15
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
I don't think so, would be too much stress for the transmission.
I drive, therefore I am.
Old 04-30-2015, 06:09 AM   #16
bronsin
bronsin's Avatar
Hmmm well I guess one in 14 is just bad luck. Or just about but not quite perfect.
The rest of the clutch was good?
Old 04-30-2015, 06:11 AM   #17
bronsin
bronsin's Avatar
Done right shouldnt bee too much of a problem but possibly puts you on the slippery slope to trouble. At least for some it would.
Riding the clutch in a yaris negev DIY / Maintenance / Service 23 07-19-2013 11:11 AM
possible clutch gone bad? DevilGirl DIY / Maintenance / Service 19 11-15-2012 06:29 AM
I make guitars. Not 56k friendly. anomoly40 Off-topic / Other Cars / Everything else Discussions 11 07-29-2012 03:52 PM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
