Old 08-21-2015, 08:26 AM   #1
nehal.hasnain
Drives: Toyota Vitz 2009
Pros & cons of these headlights
Is there any pros and cons of these type of headlights ?
Sent from my GT-I9300I using Tapatalk
nehal.hasnain is offline   Reply With Quote
Old 08-21-2015, 11:38 AM   #2
Apparently the lens scratch easily. I plan on installing these in the winter after xmas. I'll be covering the lens w/ plasti dip glossifier to protect the lens
Old 08-21-2015, 04:47 PM   #3
coheed
Drives: 08 BB LB
Also the light output is far worse than stock. My friend has these on his car and my O.E. housing put out is at least twice what his put out. Also from what he told me,you can't run HID's in them. He tried and they started melting his housings.
Old 08-21-2015, 06:45 PM   #4
Hmm, thanks for the info Coheed. Would you say the light output was not adequate for night driving, or could the hi beams be run day to day to make up for the sub par lighting?
I like the look of these but i'd just install hid's and paint the stock one black if these are that bad, they're not cheap
Old 08-22-2015, 07:36 AM   #5
If you never leave the city, the light output would be fine. Move away from urban light pollution and those things are shit.
Old 08-23-2015, 10:10 AM   #6
MadMax
MadMax's Avatar
Agreed, they are the dog's bollocks looks-wise on the car but light output is crap! I just slow down on the unlit back roads; but if you're looking for better light output, then these are not your answer!
Old 08-24-2015, 09:11 AM   #7
I decided not to go with those headlights so instead i'm going to do a diy HID halo install and paint the inside of my lights black.
Does anyone know the name/part number of a set of hid's that will fit and can be retrofitted to a yaris '08 sedan?
Old 08-24-2015, 09:40 AM   #8
PM thebarber.
Old 08-24-2015, 12:01 PM   #9
Thanks
Old 09-08-2015, 09:42 AM   #10
MUSKOKA800
MUSKOKA800's Avatar
Be sure to get extra small projector housings.
Those I got from thebarber are too large (diameter) to fit the oem sedan headlight housing. The turn signal box below the bulb location is too close to the halogen bulb location to seat the projector unit in squarely. In my case, much material need be removed which will compromise the lighting system.
Old 09-08-2015, 09:55 AM   #11
do you have a link to the projectors I'd need? I'll be starting a thread later today inquiring if anyone knows what projectors needed to be bought for an easy install as possible
Old 09-10-2015, 03:39 PM   #12
MUSKOKA800
MUSKOKA800's Avatar
Contact thebarber who has posted on you other thread. He will set you up but be sure they are small projectors.
Old 09-10-2015, 03:42 PM   #13
Thanks, I contacted him and purchased a set of hi/low H4's w/ projectors and halo's i'll let you all know how they are once I pick them up in a few weeks
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
2010 yaris Projector headlights yaris2010RS Items for Sale by private party 9 01-09-2012 05:31 PM
pros and cons of hub spacers jerome Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 07-16-2011 08:12 PM
Pros and cons of only upgrading to stiffer rear shocks? YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-04-2010 11:31 PM
Different brands of speakers....pros and cons myt In Car Entertainment + Electronics (audio / video / alarm) 2 09-26-2007 02:50 PM
