Old 10-12-2015, 01:36 PM   #1
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
New tire dealer had me rolling out with 50 PSI...??
So, I just purchased a new set of treads for my Yaris. I was on the fence between Generals and Yokohamas. Finally decided on the Yokohama Avid ENVigors, and had them fitted.
Getting out and about on the roads for some test-driving, I noticed quite a bit of bouncing and overall harsh ride. I dropped back by the tire dealer to mention the tires rode a little more harshly than I had anticipated. Come to find out, they had the tires inflated to 50 PSI, which was somewhat odd for me to discover. They said the newer tires required more air pressure for longer life, handling, etc.
Anyway, I got home and lowered the air pressure to a more reasonable 33 PSI, as per the info inside the driver's door. I must say that the car handles much better, the ride is smoother, and it sure is quieter. However, I am now confused as to the deal with the 50 PSI.
Has anyone else had this situation occur before? Is this normal, or did I just get some odd-ball tire installer?
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
Old 10-12-2015, 01:41 PM   #2
MUSKOKA800
MUSKOKA800's Avatar
Sounds like they gave you a bullshit line to cover their arses.
It is not uncommon for an installer to over-inflate tires when mounting to get the bead set. However they should then drop the pressure down to the manufacturers spec for your vehicle. They didn't finish the job.
Old 10-12-2015, 04:11 PM   #3
Rigaud
Drives: 2009 Yaris
I was about to write the same thing, they gave him a bullshit excuse. lol
30 psi in front for me and 26 psi rear. 205/45R16
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 10-12-2015, 02:25 PM   #4
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
I can't imagine how stiff and punishing the ride would be with 50 psi. I do 35 psi on my Yaris, and that is about as stiff a ride as I want on 195/60 tires.
Plus, I was told that significantly higher psi on tires can strain the sidewalls excessively and potentially cause premature blowouts.
Kalispel is offline   Reply With Quote
On tire pressures, the Yaris, and the Prius sbergman27 Fuel Economy Forum 18 04-05-2010 05:35 PM
diff. tire size should mean put diff. psi right? ezhacker1 Fuel Economy Forum 10 01-14-2010 06:48 AM
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 09:44 AM
