#1 |
![]() ![]() ![]() Drives: 2012 Yaris L, 2020 Yaris LE HB Join Date: Jan 2013
Hard-to-crank manual windows
The manual-crank windows on my 2012 Yaris are becoming extremely difficult to roll up and down. The driver's window has gotten to the point where I am afraid I am going to rip the window crank knob off. Seriously.
As a test, I sprayed a small amount of WD-40 into the side channels, and the window immediately became much easier to roll up and down. This lasted about a week before they became difficult again. I am concerned that continued use of WD-40 is not the appropriate procedure for this issue. Has anyone else suffered with this condition? Is there anything that can be done at home instead of making an appointment at the dealership? |
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
For window channels silicon spray is what the shops use.
I would look at the crank itself. I'm guessing it's binding on he plastic weather seal. |
#3 |
Because the WD40 made the window work perhaps all that's needed will be a suitable lube like the silicon nortonfb mentions.
Synthetic Oil: Its All In Your Head |
#4 |
![]() ![]() Drives: 2015 Yaris 5Dr Join Date: Mar 2015
WD40 would be long term harmful for the rubber in the tracks. I would use silicone spray its the right product for this type of use. ... my thoughts
#5 |
Thanks nortonfb, bronsin, and YarTed! I appreciate your advice.
Update: After a week or so of testing, the silicon spray appears to be doing the trick. I have no idea why this extra lubrication was needed so early in the life of my Yaris, though. |
#6 |
I had a BMW 318 TI that would require a once a year spray. If it didn't get it
the window regulator would bend. Nasty job that always drew blood. Glad it worked out for you. |
| Remote Start DIY Wiring Guide 2006-2010 Yaris | CTScott | DIY / Maintenance / Service | 272 | 01-22-2022 10:02 PM |
| DC header, AEM cai and MI lightweight crank pulley install | aspro | Performance Modifications | 7 | 09-02-2014 06:57 AM |
| Test drive 2012 Suzuki SX-4 A.W.D.. : 6 speed manual and C.V.T. ( w/ manual shift ) | Hershey | Off-topic / Other Cars / Everything else Discussions | 7 | 09-30-2011 10:54 AM |
| crank, fire, hesitate, crank, fire, run, gas smell | twowheels | General Yaris / Vitz Discussion | 9 | 06-25-2009 07:11 PM |
| Power Windows Leg Room | nwdixieboy | General Yaris / Vitz Discussion | 9 | 04-06-2006 07:19 AM |
