#1 |
FS: Rockford Fosgate Woofer
10 inch woofer with box (PM for more info)
Rockford Fosgate Prime R1 10? subwoofers provide high performance bass at an unbelievable value. This model features a laser etched curvilinear dust-cap to dissipate heat generated by the high?temp copper voice coil as well as a solid stamped steel frame with integrated frame mounted compression terminals. Best of all, they are optimized for both sealed and vented enclosures. The R1S4-10 features a 4-Ohm Single Voice Coil design, 200 Watt RMS power handling, and is optimized for both sealed and vented enclosures. Fiber reinforced painted paper-pulp cone Laser-etched aluminum dustcap High durability compressed foam surround Fatigue resistant poly-cotton spider with integral woven leads Proprietary powder coated stamped steel frame with spider cavity venting Bumped backplate with vented pole piece for greater thermal/mechanical power handling High-temp copper voice coil with aluminum former High-grade Y30 Ferrite magnet Integrated spring-loaded nickel-plated push terminals Integrated ABS decorative trim ring Last edited by Daddie Y; 12-27-2015 at 04:49 AM. |
BUMP
| Custom Lift Back Hidden Sealed Woofer Box | TinyGiant | DIY / Maintenance / Service | 42 | 04-15-2010 03:36 PM |
| Rockford Fosgate 5.25" | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 03-25-2010 02:12 PM |
| Feeler: Custom HB Woofer Boxes. | TinyGiant | Items for Sale by private party | 27 | 10-05-2009 10:30 PM |
| Rockford Fosgate or Alpine? | dccurrent | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 03-16-2009 11:16 PM |
| Woofer Mounting question | TinyGiant | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 10-31-2008 11:43 PM |
