Old 02-09-2016, 03:20 PM   #1
Kar98
Drives: 2011 Scion tC
That would explain why the lock button and remote don't work anymore on that side
Old 02-09-2016, 03:24 PM   #2
wish I could see what you're pic shows but it's a little big...
Old 02-09-2016, 03:28 PM   #3
Kar98
OK, how about now :D
Old 02-09-2016, 03:46 PM   #4
much better :) how the hell did that manage to happen?
Old 02-09-2016, 04:14 PM   #5
Kar98
More importantly, how do I fix that. All the damn dealer-installed aftermarket stuff I have on there is freaking shoddy I wish it weren't there in first place so I could do it properly.
Old 02-09-2016, 05:48 PM   #6
nortonfb
Drives: 2007
You can add bend/slight curve to the rod. If there is enough of the rod
protruding through the bracket you could drill a hole and add a cotter pin.
nortonfb is offline   Reply With Quote
Old 02-09-2016, 05:49 PM   #7
Kar98
I was thinking JB Kwik, but your idea is good also
Old 02-09-2016, 07:50 PM   #8
There isn't much slack in that cable. JB wouldn't hold, but a crimp splice might,
Old 02-10-2016, 04:37 PM   #9
Kar98
Meh. Fixed it so I can at least lock and unlock that side with the keys or with the remote. The inside lock button is without function for now. But it looks like I could loosen that little black Allen screw a bit and pinch both ends of the broken cable in there. If I care enough to fix it to rip the damn door card off again. Meanwhile I'll drive a "free candy" Yaris, I guess ;)
Help with replacing 2 button key remote hotnoodle DIY / Maintenance / Service 22 12-18-2016 05:26 AM
ad/reprogram remote starter button to key dIMs =) DIY / Maintenance / Service 4 04-30-2014 11:52 AM
Yaris 2007 remote entry doesn't open (it only closes) nicorac In Car Entertainment + Electronics (audio / video / alarm) 7 09-08-2011 11:02 AM
