Old 08-19-2016, 12:56 PM   #1
man83
Drives: Yaris HB
Arrow ►►►Custom 2" Catback - What next? Please help
Well, last weekend I changed all the pipeline.
I deleted the 2 catalytics, and only conserve the resonator. I replaced it whit a custom 2" catback, it's direct from the headers to the muffler.
Now the car has:
• CAI with AEM filter.
• DC Sports headers.
• Custom 2" catback.
• Magnaflow 14805 muffler.
So... What else you recommend me?
I was thinking in the Nology hot wire, but I have only read bad reviews about them.
Other option is start to invest in handling performance like springs and bars.
VELMAX member.
man83 is offline   Reply With Quote
Old 08-22-2016, 08:13 AM   #2
echo-francis
Drives: toyota echo
did you feel any difference with the custom exhaust?
and did you think about a lightweight crankpulley or 1zz throttlebody?
echo-francis is offline   Reply With Quote
Old 08-22-2016, 08:43 PM   #3
SirDigby
Drives: 2007 yaris 3 door
i'd recommend installing a catalytic converter. first, so your car doesn't smell like old wet turd. second, because it's a FEDERAL offence to not have one on public streets. if some drunk slams in to you and rolls your car, the officer might notice the missing smog devices. just because you may live somewhere emissions tests are not conducted, it's still federal law to have one. a $10,000 fine and jail time may result. third, a high flow catalyst will only effect performance about 1/2 horsepower, but will create that much needed 1 psi back pressure.
this is just a friendly warning. do what you want with your car. it's yours.
i'd recommend: porting intake manifold and installing 1zz throttle body; rear sway bar; lightweight wheels; lightweight clutch/flywheel; suspention
Old 09-08-2016, 12:09 PM   #4
rabbito
rabbito's Avatar
Now the car has:
i had similar mods in the begining just like yours...
mine was smoother powerband after 2000rpm from exhaust system...and a slight push after 4500rpm...guess from intake? i was expecting much more..
your opinion? everybody has different butt-o-meter..😅😅😅
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
Old 09-08-2016, 01:02 PM   #5
dude, we all breathe the air. put the catalytic converter back on.
lightweight or underdrive crank pulley next
Old 09-09-2016, 01:06 AM   #6
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I'm with thebarber on both points.
Get yourself a lightweight pulley next. (Or an entire set if you wanna go all out) It will really frees up some torque, but will make the car a bit jerky, as the engine will be more responsive.
And yes, definitly put a high-performance catalytic converter on, so it doesn't reduce performance, but still conforms to regulations.
Old 09-09-2016, 05:04 AM   #7
rabbito
rabbito's Avatar
just like invader166 stated...i went with lightweight pulley right after all your mods....you will gain slight tq and faster rpm reach 😎
Old 09-12-2016, 07:52 PM   #8
KenTK808
Drives: 2014 Yaris LE
I think you should ditch the aem filter and get a Apex'i world filter and convert to a short ram.
DC header is good
You should have gone with a larger diameter pipe for the exhaust. You should have felt a noticeable gain from removing the cats. The stock exhaust is really restrictive.
Suspension and brake upgrades are always a good choice.
KenTK808 is offline   Reply With Quote
Old 09-12-2016, 09:56 PM   #9
man83
Drives: Yaris HB
Yes, I noticed a big difference, now cutting rpm comes faster. Another change was the sound , now is very noisy, but I will install a Vibrant Ultra Quiet resonator.
All comments talk about pulleys, I think that will be the next step.
Thanks, I already started to look for a high performance cat.
The 1ZZ TB is one of the most popular upgrades that generates good results. Just yesterday I bought the TRD Sway Bar and the Tanabe Tower Strut Bar.
Hahaha! My butt-o-meter tells that the slight push is above 3.5K rpm, perhaps not having the cats on.
Definitely going to install a High Performance Cat.
I think that the crank pulley NST calls me.
Without questions I'll buy the NST Crank Pulley.
Excellente! That's what I need.
DC header is good
I had the same thought after having installed the 2" pipe, I would have liked a 2.25".
VELMAX member.
Old 01-16-2017, 10:59 AM   #10
NJP440
2010EGGHATCH
NJP440's Avatar
Drives: White 2010 Yaris Hatch
I had a 2&1/2" custom stainless catback made from the second back straight to the muffler deleted the resonator and it came out pretty decent. I also have installed the Whiteline rear swaybar, tein coilovers, UR rear upper brace, and megan racing c pillar bar (useless I know It's just for looks lol)
I'm definitely impressed with how my car performs and I'm excited to throw on the 1zz throttle body I've had sitting in my closet for a year and a half lol
https://vimeo.com/199680794
Sent from my SM-G920T using Tapatalk
IG: 2010EGGHATCH
NJP440 is offline   Reply With Quote
Old 01-16-2017, 10:55 PM   #11
man83
Drives: Yaris HB
Nice sound. I had to change the OEM resonator to this one of 24".
The sound improved a lot and I did not lose the power I had gained.
VELMAX member.
Old 01-16-2017, 11:00 PM   #12
NJP440
2010EGGHATCH
NJP440's Avatar
That's nice! What's the inner diameter? What brand? Looking to possibly quiet mine down a little lol
IG: 2010EGGHATCH
Old 01-16-2017, 11:02 PM   #13
rabbito
rabbito's Avatar
good to see somebody kept on going with their project...i will update mine with fuel injection(E85) ecu tuning soon 🖒🖒🖒🖒
Sent from my SM-N920C using Tapatalk
Old 01-16-2017, 11:44 PM   #14
man83
Drives: Yaris HB
The inner diameter is 2", this is custom made.
A friend recommended a vibrant, and I was about to install a Magnaflow Glasspack.
Tanks man! I'm loving the process.
VELMAX member.
Old 01-16-2017, 11:46 PM   #15
NJP440
2010EGGHATCH
NJP440's Avatar
I was referred to go magnaflow I'm trying to keep an even 2.5" the full way back but I definitely need something a little quieter before I get pulled over
IG: 2010EGGHATCH
Old 01-17-2017, 12:16 PM   #16
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Keep in mind that you can lose some low-end torque if you go too wide with the exhaust diameter.
…lightweight or underdrive crank pulley next
I vote for the underdrive pulley. It will also be lighter weight :-)
Sent from my LG-D801 using Tapatalk
Old 01-17-2017, 03:17 PM   #17
If you're keeping your engine NA then don't go larger than 2.25".
I decided to take the advice of a reputable and very good exhaust shop against the advice of some of the experienced YW members and I lost noticable torque. Had the shop re make a 2.25" and most of the torque came back and still has the increased top end.
That was with all the flow mods -dc header, MI intake manifold, intake, 1zz TB.
Old 01-17-2017, 03:25 PM   #18
NJP440
2010EGGHATCH
NJP440's Avatar
Ya mines getting boosties 😈 GT2860RS with custom tubular manifold and Haltech standalone. I'll post more on that as I progress. As for now I just have a closet full of parts just waiting on the money to purchase the rest of necessary parts.
Only reason I opted for 2.5"
IG: 2010EGGHATCH
Axelback or catback ?! TrYaris Performance Modifications 49 11-16-2012 03:05 PM
2" hitch ? would any one be interested in a 2" hitch reciver? Firefly General Yaris / Vitz Discussion 4 05-14-2012 10:30 AM
Custom Catback System Sabretooth Performance Modifications 48 07-10-2007 09:59 AM
Catback Exhaust by Greddy! elsteverino889 Performance Modifications 8 03-10-2007 11:05 PM
Catback exhaust? elsteverino889 Performance Modifications 5 03-09-2007 10:55 AM
