Old 11-20-2016, 05:09 AM   #1
mygirlfriendhaveayaris
projector retrofit DIY wiring issue
Recently, I made DIY a projector lens for my headlight which is 9003 to singal H1 bulb
I tired to use the HID low beam wire to low beam(+ -) and retrofit reflector + to high beam
I realized that when I turn on high beam switch, there is no power to low beam, so the retrofit reflector is on but no light from low beam (no any light)
Therefore, I tired to use 4 pin relay, 86 to high beam switch from original socket source, 85 to battery - , 30 to battery +, and 87 to low beam wiring.
When I turned on the high beam, the low beam wire(20awg) smoked and burnt.
Also, all 4 pin wire are 16 awg
Did I do something wrong?
Is there any other way to make it works except making a switch for retrofit reflector?
mygirlfriendhaveayaris is offline   Reply With Quote
9003 to h1, diy, wiring
Remote Start DIY Wiring Guide 2006-2010 Yaris CTScott DIY / Maintenance / Service 272 01-22-2022 10:02 PM
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
Relay Wiring for DIY LED Daytime Running Lights (DRL) zuberio DIY / Maintenance / Service 20 07-07-2011 08:02 PM
Two DIY wiring requests. Midnight Drifter DIY / Maintenance / Service 1 03-03-2011 09:05 AM
