Old 02-11-2017, 09:20 AM   #1
rabbito
rabbito's Avatar
1zz TB question
i failed to install the 1zz throttle body due to...
1. fu*ken coolant hose being too short and couldnt reach the throttle body..😣
2. i wanted to use stock intake box with plastic hose but couldnt fit over 60mm..lol.. 😥
is anybody using stock airbox for 1zz 60mm tb? i custom ordered stainless steel intake 2.5" from a shop to try to make it possible...(picture below..sorry for sucky drawing..) 😆
if not..how is your car running on normal intake + 1zz throttle body??
im trying to use stock box because i hate losing low end torque..i had hks intake which lost low end and gained hi end
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
Old 02-11-2017, 11:53 AM   #2
SirDigby
Drives: 2007 yaris 3 door
I took a piece of 90 degree copper tubing and plugged the coolant lines together around the corner of the head by-passing the throttle body. you would need to replace the hoses, at least 1, with aftermarket tubing. if you want to use stock air box /w accordion rubber duct, I've read that you can turn the tube around 180 degrees and it fits on 1zz. I have not tested. I have a injen CAI.
Old 02-11-2017, 11:58 AM   #3
rabbito
rabbito's Avatar
dude...that was so helpful..thank you ✊✊✊✊
Old 02-12-2017, 12:28 PM   #4
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
I think you can do without the coolant lines on the TB in Thailand. :wink
You can probably leave them in loop.
Cooland flows there to prevent icing and sticking of the throtle plate with frozen condensation vapors.. not a case in your part of the world I think :)
ncp13 is offline   Reply With Quote
Old 02-12-2017, 01:07 PM   #5
Yes, you can definitely by pass the coolant. I just bought generic coolant hose and cut it to fit for the 1zz TB. I didn't want to bypass the coolant as I live in a cold climate.
I had a TRD intake that came with a silicone coupling. It was too small to fit over the 1zz but i was able to stretch it to fit and clamp it downs with a zip tie. The stock hose is stiffer and not as easily stretched.
Old 02-15-2017, 12:05 AM   #6
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
Hi rabbito, I think 1ZZ TB is 55mm unless your using Thai TB which I saw is 60mm. You could just purchase a longer coolant hose with custom length.
I'm using 1ZZ TB with stock air intake. Tooter mentioned that I could use the stock hose by just switching the ends but it is a very tight fit for 55mm. Might need to stretch/force it a little for TB side.
Fluxtasy is offline   Reply With Quote
1zz Throttle Body Question rabbito Performance Modifications 5 12-08-2015 11:09 PM
1zz or 2zz throttle body swap BoostedTRD Performance Modifications 1 11-25-2014 10:05 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
