Old 08-10-2017, 11:42 AM   #1
white89gt
Drives: 07 Yaris Hatch
Noobie - What does this warning light mean?
Hey everyone. I am a first time Toyota owner. My sibling bought it brand new, and no longer uses it - so it was passed on to me as a commuter car. It is a 2007 Yaris Hacthback, and I noticed that every time I start it, this "cool" light comes on. Seems like it shuts back off within 30-60 seconds, but is there something it is trying to tell me? I see it means the coolant temp is low - but knowing how Ford does it (I am a die-hard Ford fan), I am thinking there must be a sensor acting up.
white89gt is offline   Reply With Quote
Old 08-10-2017, 11:54 AM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Yes it means the coolant temp is low, as it would be when first starting up. There is nothing wrong. It will go out in a short time. Also the transmission (if an automatic) will not shift into 4th until the light goes out. It stays in 3rd in order to speed up engine heat up.
Old 08-10-2017, 01:07 PM   #3
white89gt
Right on. I'm glad to hear that. Thanks for the info!!!
Old 08-12-2017, 01:20 AM   #4
SirDigby
Drives: 2007 yaris 3 door
it just means "you're cool."
but you're only cool for 30 seconds, then it remembers it's a yaris and corrects itself
ha!
Old 08-14-2017, 01:43 PM   #5
white89gt
LOL.... now I feel special every time I start it.
Go Broncos!
Old 03-26-2018, 08:49 AM   #6
crpt2008
Drives: Yaris D4D 2007
As the original poster mention it's a warning light and a red one for that matter.
The main function is to advise the driver to be careful not pushing the engine until the normal temperature is achieved. Pretty much a damage control warning.
BTW my 2007 D4D Yaris in the Norwegian winter can take a good part of 15/20 minutes to turn off. ;-)
crpt2008 is offline   Reply With Quote
Old 04-01-2018, 02:04 PM   #7
BLH
Drives: 2007 Yaris Sedan
If you have an Automatic. It will not go into the top gear until the cool LED goes out.
My Scanguage shows it going out. At 130 degrees coolant temperature.
Old 04-01-2018, 02:59 PM   #8
dogsridewith
Drives: 2007 2-door hatchback
2007 manual shift Toyota Yaris engine coolant cool indicator green lamp
red? my 2007 USAnotCA Yaris has a green cool light. Norway Yarii different?
Old 05-06-2018, 12:49 AM   #9
white89gt
Mine is also green.
cool warning light rafhelp Performance Modifications 13 07-24-2017 08:33 AM
Battery Warning Light - Different Twist maybe RutherfordmanX DIY / Maintenance / Service 3 06-08-2015 08:59 PM
Yaris 2001 The engine yellow/orange warning light in the dashboard cabbage2001 DIY / Maintenance / Service 11 01-16-2015 06:53 AM
Battery warning light stays on... routerunner DIY / Maintenance / Service 2 02-23-2013 09:53 AM
Warning light removal/replacement Midnight Drifter Cosmetic Modifications (Exterior/Interior) 4 12-12-2010 07:34 AM
