Old 09-08-2017, 06:20 PM   #1
GibbsYaris07
Drives: 2007 Toyota Yaris 3dr
Wires for reverse light bulb
I'm trying to install this reverse camera and I have the wires ready however I don't know which wires are for the reverse bulbs to splice in. I have a picture of the wire set for rear bulbs. Can someone tell me the + and - wires for the reverse.
The Gibbs Garage
2016 Lexus GS350 f-sport (my main car)
2013 Lexus RX350 (wife's vehicle)
2010 Toyota Tacoma (my second vehicle)
GibbsYaris07 is offline   Reply With Quote
Old 09-09-2017, 08:07 PM   #2
GibbsYaris07
anyone can help?
The Gibbs Garage
Old 09-09-2017, 09:10 PM   #3
Whiplash
Drives: 2009 Yaris 4DR
Can you tell by looking in the trunk?
Whiplash is offline   Reply With Quote
Old 09-10-2017, 03:44 AM   #4
What I did was looked at the reverse bulbs, looked at its wire connector, and guess (correctly) on which wire was positive and which was negative (had a black stripe on it iirc, whereas the positive was a solid color that I can't remember).
Also, gotta make sure you connect your HU's trip wire as well (I'll be doing that tomorrow as right now I have to manually turn on the camera once I'm in reverse)
http://www.yarisworld.com/forums/sho...3&postcount=10
Old 09-10-2017, 09:25 AM   #5
GibbsYaris07
I think I going to skip installing the reverse camera. I really don't need on for this tiny car anyway. lol
The Gibbs Garage
Old 09-10-2017, 12:05 PM   #6
Whiplash
You can also look for wires around the shifter if that's easier.
Old 10-30-2018, 06:10 PM   #7
2007YarisBase
Drives: 2007 Yaris Base
Reverse Wire
Of the five wires on the rear light harness, did you figure out which is the correct wire?
TIA
2007YarisBase is offline   Reply With Quote
Old 02-01-2019, 10:02 PM   #8
GibbsYaris07
nope, I tried all the wiring and it still didn't work. For this little ass car, its more trouble than its worth so I said f*** it and abandoned this install.
The Gibbs Garage
Old 02-02-2019, 09:59 AM   #9
myfirstyota
3 Yaris and counting..
In my 2008 3 door, it's the brown (I think, my eyes kinda suck with colours)
Where the yellow wire enters the connector is the spot for reverse positive.
You can see the shrink wrap where I already made the mistake hahah.
I turned the reverse light into a diy rear fog light. That's why I have the yellow wire re-pinned into the connector where the reverse positive goes.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 02-07-2019, 08:39 AM   #10
GibbsYaris07
tried that one and it didn't work.
The Gibbs Garage
Old 02-07-2019, 11:31 AM   #11
myfirstyota
Can't help you them bro. That's the one on my car.
Old 05-15-2019, 09:41 AM   #12
vinooooo93
Drives: Toyota Yaris 2006 Sedan
Red is positive, black is negative (ground)
Test with circuit tester - positive cable should light up when in reverse, negative cable should not light up when car on/off or changing gears
vinooooo93 is offline   Reply With Quote
Old 05-15-2019, 10:16 AM   #13
vinooooo93
Might be different colour to mine but here is the diagram that shows position of positive and negative cables (Terminal 5 and 6 for Sedan respectively).
Always best to confirm positive wire with current tester when gear is put in reverse - should light up. Hope this helps
File Type: png rsz_screen_shot_2019-05-16_at_01200.png (248.1 KB, 424 views)
Old 06-14-2019, 11:51 PM   #14
nashyaris
Drives: 2008 Yaris
Worked for me!
I used a test light and hooked it up to wire 5 positive (brown) and wire 6 negative on the rear drivers side light on a 2008 Yaris sedan - this was the correct reverse wire! Hooked up the backup camera like pro. Thanks for help y'all!
nashyaris is offline   Reply With Quote
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 03:32 AM
Light Bulb Specs? Violin DIY / Maintenance / Service 34 12-06-2018 05:09 PM
03 Yaris Dome light help GoldenMonkey93 DIY / Maintenance / Service 6 11-13-2014 03:06 PM
Changing Map Light Bulb justin27zamora DIY / Maintenance / Service 2 06-19-2013 11:07 AM
