Old 03-08-2018, 08:49 AM   #1
bronsin
bronsin's Avatar
Is it bad not to have an inner front fender?
Is it bad not to have an inner front fender? Driving through a berm of very hard snow The right inner Front fender was torn off. Also the front bumper cover was cracked on the right-hand side. I think that can be fixed. By me!
What will happen if I drive as it is? Will components under neath the fender be damaged?
Thanks!
PS I have the inner fender and it’s pretty much on damaged.
Old 03-09-2018, 07:39 PM   #2
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Thanks!
I mean, some pictures would be helpful, but I'm pretty sure nothing is necessarily "wrong" with it. For the most part, the yaris body panels are aesthetic and there's mostly nothing immediately behind them that's particularly important. Of course, save for the main support structures and crash structures and whatnot, but judging by your description, the only thing I can think of that may cause some serious concern for now is if the damaged pieces come into contact of things they shouldn't, such as spinning wheels and suspension bits. Post some pics of the damage and perhaps someone smarter than us can chime in.
m.flores.0928 is offline   Reply With Quote
Old 03-09-2018, 08:16 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I would think water is going to splash up onto places you might not want but I don't know how bad that is.
On Instagram
On Wheelwell
Old 03-10-2018, 11:08 AM   #4
bronsin
bronsin's Avatar
All I have left to take pictures with is my iPad. I have some but they won’t post to this site as it is they have to be reduced. Can you tell me how to do that I can’t figure it out.
Looks like the front bumper cover is cracked too. If left by itself it will eventually shredded to pieces. So that means the shop has to do the work. They want $900 for the inner fender and bumper cover.
Old 03-10-2018, 11:14 AM   #5
bronsin
bronsin's Avatar
Yeah I’m worried about water getting in the engine and the electrics under the fender and the bumper cover. So it’s got to be fixed right. I could just drive it on sunny days I’m retired I just need to go shopping and run errands. But eventually it would be used in the rain and that might be trouble!
Old 03-10-2018, 11:25 AM   #6
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
There's various aftermarket parts out there that are waaaaaaaaay cheaper. I used aftermarket inner fender liners on my 2007 and they fit okay. Good enough for the 20ish dollars they cost haha.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 03-10-2018, 02:27 PM   #7
Other issue to be concerned about is rocks/salt being spun off the tires and hitting to paint. Once chipped rust will start to form fast. That's one of the major benefits to those guards is it blocks the rocks from contacting the metal
Old 03-13-2018, 05:58 PM   #8
bairjo
http://www.city-data.com/forum/autom...ner-liner.html
Old 03-14-2018, 07:59 AM   #9
bronsin
bronsin's Avatar
Thanks for that last post that’s what I need to know! And what I suspected. I’m just going to have to bite the bullet.
Old 03-14-2018, 05:01 PM   #10
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Like Dodge Aries K says, they're dirt cheap and I don't think it would be a bad install after having replaced my headlight bulbs. It's low cost/effort vs a lot of damage that could happen as a result of the piece being missing.
Old 03-14-2018, 10:12 PM   #11
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
quite easy to replace yourself. Usually its only the front part that is shredded or if you are low enough the top part of the liner. Genuine ones are stupid expensive for things that will get shredded up (for those of us lowered). I went with cheap $15 ebay ones per side. But like most non oem parts, i had to adapt it to fit perfectly. Basically i cut it in half, and overlapped it on top of the OEM one. (imagine 2 pieces of paper on top of each other but offset) I did it this way because it didnt quite match 100% on the rocker panel side.
Check out my Build thread:
Old 03-15-2018, 07:51 AM   #12
nortonfb
Drives: 2007
Just had the same thing happen. Ripped out the driver side on a snow bank.
Engine shields are really messed up. Duct taped it all together while waiting for ebay parts. Less than 1/2 the cost of dealer.
nortonfb is offline   Reply With Quote
Old 03-15-2018, 08:43 AM   #13
dogsridewith
Drives: 2007 2-door hatchback
engine compartment pan shields scoop snow in reversing Toyota Yaris
Left and right pan shields scoop snow when backing up...can deliver grit to serpentine belt. Thinking about ways to mod.
The front brake upgrade thread - just the facts brushforhire DIY / Maintenance / Service 35 04-07-2022 07:07 AM
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 53 11-12-2017 03:03 PM
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Right front fender bender.. where to buy it new? Lafiro DIY / Maintenance / Service 4 06-15-2009 09:57 AM
