Old 04-16-2020, 05:13 PM   #1
bentjazz
Drives: 2009 Yaris--3dr MT
Do I clutch in when shifting into neutral?
Hi YWers. I know, this is a driver's ed question, and probably something I should know by now. But I've never been entirely clear on this issue, despite having a couple manual cars before buying my manual Yaris. For all those who drive manual cars out there, do you push the clutch pedal in when you shift into neutral? I always have, but am not really 100% sure if it's even necessary. Thanks in advance for any help on this remedial question.
Old 04-16-2020, 06:14 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
Yes.
Old 04-16-2020, 06:18 PM   #3
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Yes
Old 04-16-2020, 08:57 PM   #4
Yes, clutch in when you put the shifter in neutral. And something that's very important that I don't see many people doing...release the clutch pedal once you're in neutral. Don't keep it depressed. You're going to cause a lot of premature wear on the TOB.
Old 04-17-2020, 02:15 AM   #5
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Clutch in whenever you do ANYTHING in a manual. Some people clutchless shift but I'd rather replace a clutch than a transmission, so I use the clutch. Sometimes I subconsciously double clutch, its pointless but doesn't harm anything in a synchronized transmission.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 04-17-2020, 08:33 AM   #6
bentjazz
You guys are awesome. Thank you!
Old 04-19-2020, 01:07 AM   #7
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I dont lol. Whem Im causally driving I actually back off the throttle a smidge to reduce the load and pull into into neutral then clutch in then go to next gear. I dont recommend this but I do it in all my manual cars.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-13-2020, 09:11 PM   #8
blktiger60
blktiger60's Avatar
Drives: `08 HB S
Sometimes. Most of the time.
But then sometimes I shift from 3rd to 4th and 4th to 5th w/o using the clutch. It's possible if you're at the correct RPM.
- The Black Ship Yaris -
blktiger60 is offline   Reply With Quote
Old 05-14-2020, 02:29 AM   #9
bronsin
bronsin's Avatar
Sometimes you don’t have to if you know what you’re doing. In fact it isn’t necessary to use the clutch at all except for starting off from a stop.
Now that you mention it.
Old 05-15-2020, 01:05 AM   #10
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I learned how to do that when driving my friend's 18 wheeler, which has a 15 speed Road Ranger gearbox. These were a constant mesh gearbox like most motorcycles. It allowed for much faster gear changes than double clutching.
For a bit more information, this is a 5 speed shift with 3 ranges - High, Low and Deep Reduction. Normally, the Deep Reduction range wasn't used on the road unless you needed to do a hill start with a full load.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Aftermarket Clutch Q's tmontague Performance Modifications 5 03-05-2016 04:33 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
Q: when shifting into neutral... clutch? yarisugi General Yaris / Vitz Discussion 31 04-19-2012 10:51 PM
Shifting without the clutch mark293 General Yaris / Vitz Discussion 91 07-12-2010 08:56 PM
