Old 05-04-2020, 07:50 AM   #1
bentjazz
Drives: 2009 Yaris--3dr MT
Tachometer advice
Hi YWers. Since my Yaris doesn't have a tachometer, I'm looking to possibly install one so I can better manage my rpms in certain situations while driving. I'm hearing impaired, and man I have a hard time hearing the engine on my Yaris. Does anyone who has a manual maybe have any recommendations for a decent tachometer that does a good job and doesn't require an engineering degree to install? Thanks in advance.
Old 05-04-2020, 09:35 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I swapped in an OEM cluster with a tach. I don't recall what year/body it came from but it was plug-and-play. I'm sure there are a few threads around here with details...
Old 05-04-2020, 09:42 AM   #3
bentjazz
Thanks, COM. Would love to have that done. Was it difficult to do?
Old 05-04-2020, 08:21 PM   #4
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
takes like a minute. pull the radio trims and 2 screws. 2 wire connectors on the cluster.
Either find an S cluster for the MPH readout or get a Canadian one for KPH.
Check out my Build thread:
Old 05-05-2020, 03:37 PM   #5
CrankyOldMan
This. You should only have to pull the two side pieces (start at the bottom by the shifter) to get the cluster bezel off.
Tachometer install 07YarisUS Cosmetic Modifications (Exterior/Interior) 3 02-22-2016 01:44 PM
tachometer advice BEEF Performance Modifications 26 08-16-2014 03:05 AM
Tachometer 09BoostedVitz Performance Modifications 12 07-21-2011 10:48 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 01:41 AM
