Old 05-24-2021, 11:03 PM   #1
SF_Yaris
Drives: 2007 Yaris Sedan
Oil Pan installation
I changed the oil on my 2007 myself for the first time (bought used last year). The Jiffy Lube (sticker on the window) tech stripped the drain plug, so I ordered a pan from Autozone + FEL-PRO Oil Pan Gasket OS30751. This is why I like to do my own oil changes, plus the filter was tightened on so tight I needed an Irwin expandable wrench to get it off
It came with 2 tubes of RTV sealant but the product description says it's for the upper oil pan gasket and the Fel-pro composite gasket is supposed to be installed dry. Is this correct. Obviously it didn't come with instructions as it's meant for pros not shade-tree mechanics like myself.
Also, what's the torque for the bolts? I was going to pick up a torque wrench at Harbor Freight to do the job. Do you also think that the new drain plug that came with the new pan needs to be tightened? I'd just assume leave it alone. P.s. I have the Harbor Freight 302 piece socket set so I'm confident I can do the job myself. I think it's a 10 mm socket? Thank you fellow Yaris enthusiasts!
SF_Yaris is offline   Reply With Quote
Old 05-29-2021, 10:03 PM   #2
Cletus Garfunkle
Average KKT User
Cletus Garfunkle's Avatar
Drives: 2001 Echo
The rtv I've always had luck with using rtv on one side of the gasket but I'm not a mechanic just a regular Joe Shmoe who takes on some minor repairs when needed.
The Toyota manual says 80-inch lbs (inch lbs not foot lbs they are very different)
Cletus Garfunkle is offline   Reply With Quote
Old 05-31-2021, 02:53 AM   #3
remcafee
use just rtv, those goofey gaskets are a waste of time and dont work well when aluminum mates with steel
Old 06-24-2021, 08:12 PM   #4
Matt22
Drives: 2009 Toyota Yaris Sedan (blue)
Does anyone know the part number for the oil pan bolts? I am replacing the oil pan and the bolts seem brittle...I have broken two of them so far :(
Matt22 is offline   Reply With Quote
Old 07-01-2021, 10:14 PM   #5
Cletus Garfunkle
Average KKT User
Drives: 2001 Echo
Sorry for the long response time. I do believe 90119-06848 This is the right part number for the bolts 9 of them. Then two nuts which should be 90179-06326.
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
Oil pan threads stripped? xdarkxfirex DIY / Maintenance / Service 2 02-22-2021 10:31 PM
Cracked Oil Pan regal DIY / Maintenance / Service 21 09-23-2015 12:50 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Did I overfill my oil? zkay DIY / Maintenance / Service 10 06-20-2012 11:59 AM
