Old 03-04-2022, 01:27 PM   #1
naossoan
Drives: 07 Yaris 3DR
Exclamation HELP QUICK PLEASE - ABS LIGHT
Hello,
I am moving provinces in Canada so in order to register my vehicle in the new province I need an out of province safety inspection.
I called one of the local shops and asked them if the code I have right now for my ABS being inactive would cause a fail in the inspection and he said yes, it would.
I am confident I would be able to do the work myself, but my building doesn't allow me to do vehicle maintenance on building property.
Is there a way for me to deactivate this code somehow in order to pass a safety inspection?
I will fix it eventually but I don't have a lot of time to do this work myself as I am starting a new job, as I need to have my vehicle registered in the new province within 30 days of moving there.
What is the likely culprit? Loose wires, or an actual ABS sensor (which I Would need to remove the rear drum brakes to access).
Thanks
Edit: so I was able to get my hands on a scanner. the code I'm getting is C0210 Rear Speed Sensor RH Circuit
It says
C0210 ISO/SAE Reserved
Top Fix : replace wheel bearing w/C0215
Frequent Fix
Repaired Wheel Speed Sensor (WSS) Wiring w/C0215
Repaired WSS w/C0215
Replaced WSS Wiring w/C0215
So is the wheel speed sensor integrated into the wheel bearing, or what??
Thanks
naossoan is offline   Reply With Quote
ABS light on randomly toyotavios_11 DIY / Maintenance / Service 2 07-21-2025 07:00 AM
Grinding noise at low speed Trac ABS light blinking ojeysky DIY / Maintenance / Service 1 09-04-2019 11:44 AM
parking brake light on & abs light on ! car stuck in 2nd gear !!! Bony_ahmed DIY / Maintenance / Service 3 04-29-2019 06:57 AM
ABS light on (without parking brake light) WildChild DIY / Maintenance / Service 15 05-06-2018 12:40 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
