Old 07-21-2022, 06:47 AM   #1
ZombiePunkRat
Drives: 2005 Yaris
Camshaft timing sensor location
Could I kindly be directed to the location of the camshaft timing sensor? I think it needs to be replaced
ZombiePunkRat is offline   Reply With Quote
Old 07-21-2022, 07:07 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Looking from the front of the Yaris, the camshaft position sensor is on the right of the cylinder head. It's hidden under a mass of vapour lines and the air cleaner hose.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Check Valve Timing (On timing chain) EMT with a Yaris DIY / Maintenance / Service 9 11-17-2018 03:29 AM
Camshaft timing valve (OCV) o-ring size jigglebutt DIY / Maintenance / Service 2 10-24-2017 12:09 PM
Stock (factory) yaris Timing ? salmanghiyas Performance Modifications 44 03-29-2015 03:50 AM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
