Old 10-08-2023, 12:32 PM   #1
Alain93
Drives: Yaris 12
Speed sensor
Hello,
do you know where is the speed sensor on a 2012 Yaris L 1.5l manual transmission?
I removed the battery mount once, but could not see anything resembling the speed sensor on the top of the transmission.
I found a speed sensor on Rockauto, not sure it's the good one.
Alain93 is offline   Reply With Quote
Old 10-09-2023, 01:31 AM   #2
rayfloyd170
Drives: Yaris 2016 1.3 Manual
check this out. Take note of Left and Right part number
https://www.toyodiy.com/parts/s?v=U_...GMRKA&s=speed+
rayfloyd170 is offline   Reply With Quote
Old 10-09-2023, 08:13 AM   #3
Alain93
Drives: Yaris 12
Thank you,
I found them on Amazon, and on Rockauto they are under Brake "ABS wheel speed sensor". I was looking under Electrical "Speed sensor".
Vehicle Speed Sensor Problems jacl3 DIY / Maintenance / Service 1 06-23-2025 01:16 AM
Abs and slip indicator on need help speed sensor Jeffbass DIY / Maintenance / Service 0 04-28-2016 01:38 PM
Rear Speed Sensor Install Help? (ABS Sensor) towerofpower DIY / Maintenance / Service 2 04-07-2014 06:32 PM
Bad Speed Sensor? dmehak DIY / Maintenance / Service 33 01-05-2011 09:17 PM
