Old 03-16-2024, 03:34 PM   #1
loopo
loopo's Avatar
Drives: 2008 Toyota Yaris Hatchback MT
1ZZ Throttle Body Upgrade
I just got the 1ZZ throttle body from a 2005 Corolla. Part# 22030 - 0D030
It takes 4 bolts and has 2 angled hose hookups.
Do I need to swap over the black plastic rivet part of my stock throttle body onto the 1ZZ?
I have a 2008 Yaris hatchback 1.5L manual.
loopo is offline   Reply With Quote
Old 03-16-2024, 10:48 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
You don't HAVE to but some users have reported drivability issues when doing this mod that is usually fixed by swapping boards. YMMV.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 03-17-2024, 01:22 PM   #3
loopo
loopo's Avatar
Okay thanks
Old 03-17-2024, 03:57 PM   #4
Compeer
Drives: NCP90 TRD Yaris Manual
You will need to swap the black pastic board riveted on yes, otherwise it will throw error codes and ether not drive at all or put you in limp mode. Its an easy swap drill out rivets and swap then bolt or revite back together. You will also need to adjust the idle with the little hex screw hidden under the yellow glue.
Compeer is offline   Reply With Quote
1zz throttle body +what intake?? 0BD1Kenobi Performance Modifications 17 10-21-2019 07:45 AM
1zz Throttle Body Question rabbito Performance Modifications 5 12-08-2015 11:09 PM
[Buy] throttle body 1zz yaris 1800cc to 1500cc TS Nets Items for Sale by private party 2 04-25-2010 10:27 AM
1ZZ throttle body aucorium Performance Modifications 44 03-14-2010 12:57 AM
1ZZ-FE throttle body crxgames Items for Sale by private party 1 04-27-2009 05:19 PM
