Old 11-07-2024, 08:21 PM   #1
nikonNUT
Drives: 2010 3 Door L
Clock Spring Failure?
Good evening all,
Had an odd issue and need some advice. Probably 8 years ago I ordered a cruise control kit from CT Scot and installed it. Absolute breeze and have been happy ever since until about a week ago. Started have an issue where sometime the cruise would arm and work fine and other times where it would not. It finally quit turning on at all 2 days ago. Figured I would grab a new stalk and swap it out and all would be well. NOPE! As a real head scratcher the norn works and no airbag warning lights but the cruise still won't arm unless... I turn the steering wheel all the way to the right or all the way to left. Then I can turn it on but I can't set it. I want to say clock spring but with the horn working is that possible? I mean I guess the horn, just completing a circuit, might still work while the resistance of the cruise stalk could cause issues but I wanted to ask people smarter than me! Thank you for the help and I look forward to hearing your thoughts!
"Sanity? What would I do with something as useless as that?”
nikonNUT is offline   Reply With Quote
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Clock Spring ohnodarlin Willing to Buy by private party 0 01-08-2013 03:34 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Track Suspension id3379 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 85 06-11-2009 05:59 PM
