Old 07-31-2007, 10:26 PM   #1
yuiedie
Drives: '07 liftback
white residue in exhaust pipe
car is stock, just out of curiousity i looked into the exhaust pipe and saw some white residue stuck to the inside. at first i thought some idiot stuck some plastic bags or something inside to fcuk around but when i tried to scrape it off it was powdery. any idea what it could be, maybe its just a by-product of the exhaust gases?
yuiedie is offline   Reply With Quote
Old 08-01-2007, 12:21 AM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
you need to stop stashing your dope in your intake, it will get sucked in to your motor and blown out your exhaust....
was there a lot.... or just a little, can you take a picture? sounds like it may just be a bit of excesive carbon, maybe form using shitty gas?
Old 08-01-2007, 12:30 AM   #3
yuiedie
not much residue, but enough to see from the back. chevron and shell must be shitty gas.
Old 08-01-2007, 12:54 AM   #4
Black Yaris
der Zeck
well I always you shell, and only shell.... so that is not your problem, but I use premium 75% of the time..... but my car's intake and Exhaust are nowhere near stock.... we do not have chevron here, so I do not know..... could just be the California gas.... I hear there is some weird stuff in there, I had a couple buddied buy some cars from there recently and they were tuned to California gas.... they had to be retuned to standard 93 octane
Old 09-19-2007, 09:56 PM   #5
calvin7897
Drives: 2008 yaris 3d
White residue in the cylinders is usually found on the spark plugs, and is from detergents in the gas that help keep you system clean. Never heard of it coming out of the tailpipe though.
calvin7897 is offline   Reply With Quote
Old 09-19-2007, 10:14 PM   #6
BailOut
Steals terrorist's lunch
BailOut's Avatar
yuiedie, do you drive the car hard? If so the powder is from gelled and dried fuel additives that didn't have a chance to burn off in the cylinders during high RPMs. It's a sign that you need to slow down.
If not you need to take the car in to the dealership to have the catalytic converter inspected because the powder is likely ceramic dust from a failing or failed component in there.
- Brian
Share the Road
Old 09-19-2007, 10:23 PM   #7
Black Yaris
der Zeck
we do have a catalytic converter TSB, but it is for sulfer smell..... posibly related to his issue?
Old 09-21-2007, 07:17 PM   #8
yalease
Drives: 2008 Yaris HB
lol.. white residue
yalease is offline   Reply With Quote
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 04:05 AM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
Fujitsubo Exhaust!! MC-BPT Sponsors Classifieds Area 17 11-16-2006 10:36 AM
