Old 08-01-2007, 06:33 AM   #1
tfoxx
Drives: 2006
A/C Drain Clogged
Anyone run across this yet? Started happening yesterday, noticed the passenger floor board was all wet and when I turned left this horrible sloshing noise was coming from underneath the glove box.
Located the small rubber hose leading to the outside and was able to get the water out, but it keeps stopping up. Anyone have a quick fix for this or am I going to have to take it in?
tfoxx is offline   Reply With Quote
Old 08-01-2007, 06:36 AM   #2
can you try to push something long and flexible down the drain hose, like a pipe cleaner, try and push out whatever is clogging it?
Old 08-01-2007, 06:47 AM   #3
tfoxx
Drives: 2006
I have seen how I can detach it yet. There doesn't feel like there is anything in it, and once I wiggled it around yesterday it drained pretty fast.
I'll see about removing it though and trying your suggestion - thanks.
Old 08-01-2007, 08:39 AM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
Dealership
Old 08-01-2007, 08:48 PM   #5
Toyota Technician
Drives: 2007 Red Yaris LB MT
the dealer i work at actually has a spray in foam that wil expand all the
way upthe hose, it works well and pipe cleners will help get the larger debis out this is a common problem on all toyotas. i dont think the cleaner is toyota so u may be able to find it at a parts store.
Toyota Technician is offline   Reply With Quote
Old 08-02-2007, 07:14 PM   #6
deadworld
Drives: 2007 4dr yaris
yeah dont poke to deep might puncture the evap core
deadworld is offline   Reply With Quote
Old 04-18-2009, 02:20 PM   #7
odin
Drives: 2007 yaris liftback
A/C drain
Mine just did this the other day. Dealer charged $90 to unclog. Where is the tube? Next time I will clean it myself. This is the first time and car has 78000 miles.
odin is offline   Reply With Quote
mantenimiento del A/C Kitt Central and South America 32 05-05-2011 03:07 AM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
Do u guys set to Fresh Air for A/C? hans_fh General Yaris / Vitz Discussion 17 06-12-2007 03:24 PM
A/C & Aftermarket intake KSIbucky DIY / Maintenance / Service 2 03-26-2007 09:08 PM
A/C smelling weird? Yaris_PR General Yaris / Vitz Discussion 11 08-04-2006 08:26 AM
