Old 08-06-2007, 10:00 PM   #1
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
Tire Pressure
Are you supposed to fill your tires to the max. pressure stated on the sidewall? If not, how much should you?
cm07yaris is offline   Reply With Quote
Old 08-06-2007, 11:18 PM   #2
cm07yaris
anyone?
Old 08-06-2007, 11:24 PM   #3
OldSuperSport
Owner/Operator
OldSuperSport's Avatar
Drives: 2007 Yaris Hatchback
Usually you would keep the pressure at the sidewall PSI. I think its more important these days with the super low profile tires. In the old days you could overpressure a tire and get better mileage (a little more) at the expense of faster center tread wear.
OldSuperSport is offline   Reply With Quote
Old 08-06-2007, 11:37 PM   #4
cm07yaris
so go with the sidewall max pressure? thanks
Old 08-06-2007, 11:37 PM   #5
cm07yaris
tires came mounted and balanced at 35psi, sidewall max is 50
Old 08-06-2007, 11:40 PM   #6
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Toyota manual says 32 psi, their recommendation for handling and comfort.....pressure listed on the tire sidewall is a maximum according to the tire manufacturer, at this psi mpg will be better, but traction while cornering may suffer, ride will be harsh, and some say tires will wear in the center of the tread quicker.
Personally I use the max sidewall pressure for mileage.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 08-07-2007, 12:03 AM   #7
Indianspringsaz
Drives: 07 Bitchin Blue HB
Max-44psig. Thats where I run them
Indianspringsaz is offline   Reply With Quote
Old 08-07-2007, 12:16 AM   #8
mr_squiggle
Upsidedown
Drives: 2007 Yaris 1.3l
Mine are kept at 40psi
Seems to do the trick nicely.
Conversation with a friend who owns a turbo car
"Why would you do that to a yaris? It's a sissy car"
My reply.
"Because I can... and to scare people..."
mr_squiggle is offline   Reply With Quote
Old 08-07-2007, 12:19 AM   #9
cm07yaris
thanks for the input, i'm also not running the stock tires. i'm running 205/50-16, i'll just have to experiment a little, i'm guessing 45+ should be fine for my needs. thanks again
Old 08-07-2007, 01:30 AM   #10
Black Yaris
der Zeck
Black Yaris's Avatar
Oh God.... not this debate again...... 32-35psi is the pressure recommended for this car depending on the tire sizing you upgraded to.... som of ya'll are running much too high of pressure for daily driving, you are going to wear tires out way too fast....
Old 08-07-2007, 07:50 AM   #11
Motorhead6T5
Motorhead6T5's Avatar
Drives: 07 NCP96
+1 Ride must be harsh too. I run mine at 32.
Motorhead6T5 is offline   Reply With Quote
Old 08-07-2007, 08:37 AM   #12
grampi
Drives: Corolla
If the recommended pressure is 32, then 37 psi is probably about the optimum pressure.
grampi is offline   Reply With Quote
Old 08-07-2007, 09:26 AM   #13
Black Yaris
der Zeck
I run my 17's with 205/40's at 35 psi for the best ride, handling, and tirewear...
Old 08-07-2007, 10:59 AM   #14
voodoo22
Drives: Yaris Sedan (auto)
I keep mine at 40 psi.
A little harsher ride, but I like the way the car handles with less sidewall flex.
I don't know how much better FE I get with 40 psi, but it can't hurt.
voodoo22 is offline   Reply With Quote
Old 08-07-2007, 08:27 PM   #15
Thotprawsis
Drives: '07 Blazin' Blue LB
I'm running the stock tires. I've had them @ 32psi when on long trips for comfort. 40psi seems to improve the preformance, but very harsh ride. 35psi is where I'm at now and seems to be a good compromise for every day use.
Thotprawsis is offline   Reply With Quote
Old 08-07-2007, 10:38 PM   #16
ricky2k1
Drives: Black YARIS RS
the sticker on your door has the optimum tire pressure for your car.
anything else could cause uneven tire wear.
ricky2k1 is offline   Reply With Quote
Old 08-07-2007, 11:02 PM   #17
churp
churp's Avatar
This only pertains to the stock tires w/stock rims. Changing rim width, tire size or aspect ratio, spring rates, how you load your vehicle, etc. makes the manufacturers recomendations meaningless.
____________
Old 08-08-2007, 08:16 AM   #18
grampi
Drives: Corolla
Not true. I can tell you from personal experience the pressure listed on the driver's door IS NOT the optimum pressure. I have found that running your tires at about 5 psi over the recommended pressure increases tread life, improves handling (stiffer sidewalls), reduces tire noise, and improves fuel economy. The only thing that's better at the recommended pressure is the ride, and even then, only somewhat better. Some people run their tires at the max pressure listed on the tire's sidewall, however I've found door pressure +5 is usually the best compromise between getting all the other bennies and a smooth ride.
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 09:44 AM
Tire Pressure and Gas Economy KittenRD General Yaris / Vitz Discussion 11 01-25-2007 10:54 PM
Tire Pressure slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-05-2006 12:37 PM
stock tire pressure... argylesocks Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-16-2006 12:28 AM
