![]() Drives: 2007 Black Yaris Join Date: Sep 2010
Help Please! Specific Fitment Question On 16x7 +15
2007 Yaris LB - Stock
I'm ready to pull the trigger on 16X7 +15 XXR - 513's. I will not be lowering my car now or ever in the future, so will this reduce the rubbing problem everyone seems to be having with these rims? I am coming from a lifted 4Runner so I'm completely new to the small car/rim set up. I am sorry if there are already posts on this exact topic, I couldn't find any. Most people have their cars lowered +/- 2", but I'm not a fan of that look so I'm hoping I'll be able to avoid most of the issues. Also, what size tire do you suggest? |
Edit: After some more searching...would front camber bolts and rear shims help with reducing the amount of rim sticking out past the fender?
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
I would suggest you find a wheel with proper offset.
16x7, ET42-45, 205/50/16 will make for an excellent fitment on stock suspension. EDIT: There are a few other Panasport inspired wheels similar to the XXR-513 that are available in ET40 that will work very well on the Vitz with the right tyre. Last edited by kimona; 02-22-2011 at 10:58 AM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
You can get a similar look with a safer fitment if you go with a Rota RB, Konig Rewind, etc.
+15mm is going to poke. Is that what you want?
You'd have to stretch tires and use negative camber to get those anywhere near the fenders. They might not rub because you're not lowered, but they will visually stick out.
#7 | |||
Overall, I just noticed that everyone who has rubbing issues has their cars lowered an inch or more. Since I'm not planning on ever lowering the car, I figured it would eliminate the fender rub...especially if I run bolts/shims. Is there a downside to using either of those to achieve a slight negative camber? |
![]() ![]() Drives: 2007 Yaris RS HB Join Date: May 2007
Like Kimona suggested, the Panasport inspired wheels are a great option. I also liked the XXR 513 but the offset turned me away. I am getting the Rota RB in a 16 X 7 rim with a 40 offset. Even with my 1.4"/1.3" drop, I should not get any rub with 195/50/16 rubber. The rims are attractive, relatively lightweight and certainly affordable.
Good luck |
#9 | |
| Fitment Question..help | 8thcivic07 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 04-24-2010 03:09 AM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 07:42 PM |
| Wheel Fitment Question | PuntCuncher | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 11-06-2009 04:14 PM |
| Specific Subwoofer/Amp Question | skigil | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 05-06-2009 10:22 PM |
| Tire Fitment question | Ryu | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 01-14-2007 02:47 AM |
