Old 11-05-2009, 05:27 PM   #1
PuntCuncher
Wheel Fitment Question
Hi. I did a fair bit of searching for this specific application, but wasn't able to find what I was looking for.
I have a 2010 Yaris 3dr liftback, and a set of wheels I'm hoping to get on the car.
15"x5.5"
40mm offset
4x100 bolt pattern
59.1mm center bore
Tires are 195-55-15
I know the Yaris bore is 54.1mm. Is that going to be too small for these wheels?
Thank you in advance.
PuntCuncher is offline   Reply With Quote
Old 11-05-2009, 05:34 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
15"x5.5"
40mm offset
4x100 bolt pattern
59.1mm center bore
Tires are 195-55-15
nice screen name
what you need are called hubcentric rings..
www.discounttiredirect.com sells very nice aluminum ones.
but i highly doubt they'll have rings with those specs.
why are you buying such skinny wheels?
*troll alert, or possibly existing member alert*
Old 11-05-2009, 05:46 PM   #3
PuntCuncher
nice screen name
Wheels are from a 95-98 Nissan 200sx that I had an extra set of.
Thanks anyways.
Old 11-06-2009, 12:07 PM   #4
PuntCuncher
Sorry for the double post.
I just want to clarify, since I'm fuzzy on this, even though everything else matches up fine, the center bore requires a spacer which I will have a difficult time sourcing?
I don't know much about wheel fitment, but will the slop in the bore put too much stress on the lugs?
When I had my old car I gave a set of wheels to a friend who had an EG civic (92-95). His center bore was 56.1mm IIRC, and they worked great.
I just got this car on sunday, found this forum monday, and have been looking through all the stickies and the rest of this forum since then, so please bear with my ignorance. I'm just trying to cover my bases and not screw up a brand new car. Thanks for the help.
Old 11-06-2009, 01:02 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
you'll be fine on just the lugs. it's a very light car, just make sure to use a diagonal pattern when tightening the lugs down.
the rings would only end up being 2.5MM thick, i highly doubt you'll find any like it. give www.discounttiredirect.com a call though, i've been wrong before!
Old 11-06-2009, 01:24 PM   #6
NonOffensiveUserName
Drives: A P.C. Yaris
Thank you Tamago. I'll give them a call today.
*New Username
NonOffensiveUserName is offline   Reply With Quote
Old 11-06-2009, 03:14 PM   #7
Ok, I just called discounttiredirect. Great customer service BTW.
The closest they had was a 60mm. I asked him if it would be possible to get those and take a dremel to them, but he said since my wheels aren't aftermarket, hubcentric rings probably wouldn't fit my application.
He recommended that I put them on the car as is, and using the star pattern to ensure they are centered. If there are any vibrations I'll obviously remove the wheels and look for a set that is better suited to this car.
I gotta get a new tire on one rim, but once that's done I'll report back.
40mm, 4x100, bore, center, offset
Wheel fitment question helladrift Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-02-2008 12:06 AM
Wheel fitment? PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-26-2007 12:18 PM
Tire Fitment question Ryu Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 01-14-2007 01:47 AM
question, do I need my hubs protected by a wheel cover foober Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-28-2006 12:25 PM
