Old 06-30-2009, 10:49 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
Rub a dub dub...
I have an 09 3-door with OEM 185/60/15 on MB 'Weapon' wheels (15X7 4-100 35GM) with 13mm rear hub spacers. Also, car is lowered on DF210's. The wheels and tires look awesome, but I'm getting some pretty annoying rubbing in the rear when going over dips/valleys in the road. It doesn't seem to happen with normal up and down bumps/potholes, just any time the rear end dips down more than the front. It seems to be only happening on the right rear tire, which is weird.
Also, the front left tire is rubbing when I turn against the locks to the right, such as in parking or pulling into my driveway.
Is there anything I can do to eliminate the rubbing? I know it's only rubbing on plastic (I hope!), but it sounds kinda scary, especially to passengers who aren't used to the sound.
Old 06-30-2009, 11:36 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Sounds like you are rubbing on the guard , try Tamago's washer idea
on the bottom bolt's of the hub spacer's or machine your hub spacer's with -1.deg camber
Old 07-29-2009, 08:58 PM   #3
MGargano
Has anyone else found their Yaris to be asymmetrical in the rear? I have 13mm hub spacers installed and the right side definitely sticks out further than the left. I wouldn't mind so much except that the right side is rubbing when going over dips in the road, which is annoying. Aside from the washers, is there any plastic (etc) that I can safely eliminate to stop the rubbing?
Old 08-01-2009, 02:25 PM   #4
MGargano
I never would have believed something as simple as two little washers would have such a big impact! The rubbing is gone!
Old 08-01-2009, 07:51 PM   #5
Mead
Drives: BSP Yaris LB 2007
mine too, passenger side sticks out prolly >5mm
and the rubbing is around the rear bumper split line... not top center
Mead is offline   Reply With Quote
Old 08-01-2009, 07:55 PM   #6
MGargano
I think that's where mine was rubbing too, along the bumper split line. Try the washer thing.
Old 08-02-2009, 03:44 AM   #7
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
I had 4mm differance between the Right Rear and left rear,
beleave it or not , 2.5-3mm of that was guard miss alignment ,
which took the Toyota tech 3mins too fix (pulled guard out )lol
the rest of the rear was well within factory specks .
Old 08-03-2009, 12:05 PM   #8
enviri
enviri's Avatar
Drives: 2010 Yaris
yeah i have a pretty big difference in my rear end too, what do you mean by guard misalignment?
Aftermarket exhaust systems that do not rub on the road! fuji Performance Modifications 10 04-28-2009 06:22 AM
Does +43mm rub? Split Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 02-28-2009 07:39 PM
New Wheels and TRD springs tires rub gmodder Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-25-2009 11:21 AM
want 2 lower with tein but have tyre rub HELP! MR. CANTON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-24-2007 04:16 PM
Ruba a dub dub in the rear slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 07-22-2007 08:27 PM
